Fusing
  • davidshaw57
    • Jan 2020
    • 20
    Fusing
    Is there anyway to fuse the ESC or motor to prevent it from burning up.
  • eXoNerated
    • Jun 2020
    • 233
    Yes but better is to stay within the rated specifications of the equipment or are you repairing a drive?
    Regards
    Hubert
    • davidshaw57
      • Jan 2020
      • 20
      Seaweed got wrapped around prop and must have overloaded. I thought the battery was depleted but it wasn?t.
      • eXoNerated
        • Jun 2020
        • 233
        Did it burn up the controller? U say Seaweed if this means you run in salt be sure to flush the cooling system with freash water afterwards. U can use W ater D ryer 40 to remove all the moisture when you are done flushing the system.
        Regards,
        Hubert
        • davidshaw57
          • Jan 2020
          • 20
          Generic term , I was running in a big pond.
          • eXoNerated
            • Jun 2020
            • 233
            Oh hydrilla. Did you burn up something?
            • jingalls007
              • 1015
              You can get cap banks to help with ripple current. Steve sells them.
