Stuffing tube
  • Jonathan DeMaria
    • Jun 2020
    • 114
    Stuffing tube
    Why does my liner in the stuffing tube move up towards the motor in my blackjack 29" v3 & how do i fix it??
    • 4340
    Could be a mis-alignment between the motor mount and stuffing tube, or a cheap stock collet with a lot of runout. If those check out, you can pull the liner forwards, clean it with some alcohol, put a few wraps of teflon tape around the end, then slide it back in. The teflon tape creates an interference fit, so you may need more or less to get the desired result.
      Nice tip. ^^^^
      • properchopper
        rcgoatbuild@snotmail.com
        • 7708
        The twisted flex has a lay for CCW props that climb upward towards the motor collet which acts on the teflon and pulls it upward.
        • Jonathan DeMaria
          • Jun 2020
          • 114
          What does a lot of run out mean? New to fe boats
            • 4340
            it means it's either poorly machined out of center or fits poorly on the motor shaft. Both visible as a wobble when spinning.
