Hi Hubert , Tyler,
yes Tyler is right. The step by step of the JAGs team rigger is the best way and if J?rg would run on 10S he will hit 250-300 mph. But you have always some limitations . How long is the distance to accelerate the boat and after the timing you have to stop. So the JAGs team does the right math to get the right total boat weight to power to get the best for the competition. All count , more cells weight more will need higher power to reach the same speed after the same distance and only if the race course is bigger you can win with this higher power set up. Power is not all. It helps but the right aerodynamics possible help more. Hubert i sent you the article about Limits for Straight Away racing. This is for combustion motors and they start from a turn with plenty of basic speed. They have not this very hard dragracing acceleration that the current record boats use.They all start from laying like a gator in, under the water and then push in seconds up to topspeed. So if you have unlimited power best way will be a dragboat design. The other thing is that J?rg has over years contact to the batterie manufactory and they build this spezial cells extra for his team. As i know they have 3000 mAh and 5000 mAh cells.
So in some case the smaller one are to small and in the other the bigger are to big. The motors are not the limit today. We have designed motor for electric turbo charger that turn up to 250000 rpm. With outrunner designs we have motor/alternators that have to surface speed of Mach2 with no flux limiting bandage in the airgap. And as you know the regulations say 10S 2P , hey that power is incredible , water will cook in time. So you see there are many ways to go and many mistakes to do. We will look to help you to find the right way , but you have to select all this input to your owen mind construction as we do not know what in your brain are the best components and design rules that will be the recodbreaker design. 1983 my Crapshooter with 30 1,5 Ah nicad cells and spezial wound amature motor with brushes was my way to reach 50 mph . Today every toyboat from China can do this speed. So the world is changing and you know that i test many designs and set ups but for some it is better they are secret wonders that are not competiv. Every here has his owen crazy thoughts . Do you know about our front propeller canard boat designs ? This boats run well , do not flip as they have the self trust limiting design. But at the end we are fast but not the winner. We spend many time and thinking and build many prototype to look how it workes.
Happy Amps Christian
