Adding lipo
  • Spat
    • May 2020
    • 31
    Adding lipo
    I was given an old hydro marine bud hydroplane that has a Hacker B50 10XL motor and a Jeti master navy 77 -3P esc. Boat has no batteries with it so don't know what it was running on. Any info about the esc would be great.
    This may help.
    • Spat
      • May 2020
      • 31
      Thanks, I saw that too but the one I'm looking for wasn't listed.
        That motor in that hull usually runs on 4S1P.
          Motor info:
          • Spat
            • May 2020
            • 31
            You mean 4S lipo? That would be great as I have them. But I am unable to find out the specs for the speed control if it can handle them. JETI Master Navy 77-3P. It's the 3P that is screwing me up.
              I never knew what the 3P meant or worried about it when I ran those.
              If it does not say OPTO on it then it has a BEC circuit.
              You can use NiMH or Lipo on these. If using NiMH you can use 12 cells, not sure of max Voltage though??
              • Spat
                • May 2020
                • 31
                It does say Opto on it and 8-30 nc
                • Dr. Jet
                  • 1759
                  3P means 3 Phase. A brushless motor, is in fact, a 3-phase motor. It was rated at 77 amps. Since it was designed for NiCds, there probably isn't a low-voltage cutoff. Capable of 36V or about 8S. 10S might work, but beware.....
                  A nation of sheep breeds a government of wolves
                  • Spat
                    • May 2020
                    • 31
                    Thanks, that is what I was trying to find out. Looks like I'll be buying a new speed control
