I made a mistake with epoxy
  • Norwest
    • Mar 2014
    • 165
    I must have made a mistake with epoxy. I applied epoxy a few days ago and still sticky. Most likely not proper measured. Remedy is what I need. I have never had this happened. Epoxy is covering balsa raw, thanks for an answer is what I need. Thank you!
  • longballlumber
    • 3119
    You might try scraping it off with a razor blade or sharp putty knife...
    • MadProps
      • Mar 2017
      • 236
      remove with acetone and scraping tools....I would also dilute some hardener with same acetone and soak into the epoxied areas and hope it cures so you dont get soft wetted balsa conditions like nitro fuel on raw balsa
      • Capt'n Crash
        • Mar 2015
        • 166
        I've always used isopropyl or rubbing alcohol you can get from the drug store to remove unhardened epoxy. Works well without the fumes from acetone.
          • 4335
          Not sure what happened with your mix ratio, but just pointing out that mixing by weight is different than mixing by volume.
          • Norwest
            • Mar 2014
            • 165
            I found a way with subject. Baby power by accident, slick as a whistle.
