Delta force / pirate 35
  • vvviivvv
    • 1148
    Quick questions
    is the hull design (lower hull) much the same i see there is 1" difference...
    And setup wise, 1521 1y on 5s 45mm 3 blade prop?
    or lehner 2260 8/9 and 6s similar prop ?
    what do people run 2x 3s or 2x 6s for batts? would like ~60mph decent run time and not too high on temps.
    i have the NEU or a ESC to work with the lehner, so either is a option...
    Is it necessary to put a layer of carbon in the hulls or are they okay?
    I think i prefer the pirate looks but open to options..
    Thanks guys,
    Uk SAW record holder
  • StevenBryant
    • Nov 2012
    • 366
    The Deltaforce has a ride pad and the Pirate does not apart from that they are very similar in design, the pirate seems to have a larger freeboard and apparently handles the rough better than the DF. This information came from the a different thread I was reading the other month..
    The DF boats are really well made and don?t need reinforcement if they are fitted with ply rails, if not then a layer of CF will help to stiffen the bottom of the hull.
    Sent from my iPad using Tapatalk
    • vvviivvv
      • 1148
      Good to know, I’d assume the deltaforce would draw less amps but the trade off it getting bounced around a bit more ?
      • StevenBryant
        • Nov 2012
        • 366
        Originally posted by vvviivvv View Post
        Good to know, I?d assume the deltaforce would draw less amps but the trade off it getting bounced around a bit more ?
        I?m a huge fan of the original DF, very fast boats but they had a tendency to not really like choppy water, have you looked at the new Seaducer monos? Jerry makes an awesome boat at a good price with some cool gel coat colours.
        • StevenBryant
          • Nov 2012
          • 366
          If your sticking with the DeltaForce boats then I would recommend the Pirate 35
          • jaike5
            • 564
            I run the DF Storm, 1521 Neu , 1914-15-60 , 4s 5000 stix not bricks. with the non lifting prop, and cog 34-35 % temps 120*flat skid fins not the tear drop. really stable.
            Jay.
            • vvviivvv
              • 1148
              I hadn't but did some quick research and the DF seem to come up trumps more...
              • vvviivvv
                • 1148
                Wont be racing or anything, just need to build a backup boat for extra fun / run times at the lake, especially if its a little more choppy... so by the sounds of it a DF pirate fits the bill the best?
                thoughts on the OSE carbon raider? I guess i can't go wrong with either, id prefer to use a stinger strut just for looks
                back to setups, am i better off with a lower weight boat 4s and higher KV in this size range or for longer runs lower temps go 6s with a 1521 1y / 5s? / equivalent Lehner
                • vvviivvv
                  • 1148
                  From some research i've done thinking to go with my 1521 1y, 6s2p, x445/3 and a swordfish XF 220A
                  Anyone care to chime in before i start purchasing what i need? i already have the motor..
                  Which is the best hardware kit to go with? (i've already got a wanted in the sales section - but if nothing turns up ill just buy new)
                  • Nick1979
                    • Sep 2020
                    • 118
                    This is a solid set up. With 6S and 1521Kv motor, you'll be in the mid 30K RPM's roughly. Can you update us on your progress?
