Can SSS 3674 2075Kv Motor run 6s?
  • jmdmbsc
    • Aug 2019
    • 14
  • boatsrnew2me
    • Oct 2016
    • 474
    this link here says max voltage is 30 v so in theory yes it can .should you though is another story .
    • Capt'n Crash
      • Mar 2015
      • 166
      Kv is a little high for 6s. It would run best on 4s.
      • Revolt Flash
        • Aug 2015
        • 437
        We run twin SSS 3674 2075 on a Zonda with 120 amp ESC's and 3 blade 48 CNC props. We keep run times around 3 minutes and in runs fine.
          • 7990
          What does the OP want to put the motor in? Running a 2000+ Kv motor on 6S means that prop choice will be critical, a little too much and - pow. Too, this is a relatively small motor rated to just 73 amps max. You can load it more, but it will get hot so limiting run time will be important. It won’t spin a big prop efficiently so large single motor hulls are probably not a good idea.
