What to use?
  • Damien
    • Dec 2019
    • 19
    What to use?
    I?m running a 3/16 flex cable just wondering what is the best thing to use between drive dog and strut gap??
  • 30nitro
    • Feb 2018
    • 330
    Normally just a gap between drive dog and strut...no washer or bushing.... Cable shrinks a bit when under load, You don't want the drive dog hitting the strut at all.....
    • HTVboats
      • Jun 2011
      • 936
      https://www.offshoreelectrics.com/pr...s%2810+pack%29
      Put 2 washers on and a bit of grease and the drive dog will never hit the strut.
      Mic
      Mic Halbrehder
      IMPBA 8656
      NAMBA 1414
        • 4340
        I prefer to just run with an appropriate sized gap, and no washers.
        • RaceMechaniX
          • 3024
          The gap for a collet set-up should be set based on the length of cable. For short cable lengths, smaller gaps around 1/8" are OK. Longer cables should have a larger gap, start with 3/16".
          Look for signs of contact between the end of the strut and drive dog and adjust as needed. Ideally, you do not want too much gap.
          Tyler Garrard
          NAMBA 639/IMPBA 20525
          T-Hydro @ 142.94mph former WR
          • Damien
            • Dec 2019
            • 19
            Thanks guys for feedback I also noticed it takes in a bit of water between gap and runs up the back of strut through the stuffing tube and in the boat any ideas how to stop it
              Than you for confirming something I have pondered for years!
              • NativePaul
                Greased Weasel
                • 2770
                A piece of silicone water tubing or heat shrink tubing over the stuffing tube on the inside of the boat so it lightly touches the flex or wire, will stop most of the water coming up the shaft.
                • tales
                  • Oct 2019
                  • 4
                  marine grease on the cable
                  • Revolt Flash
                    • Aug 2015
                    • 437
                    Marine grease works really good for me sporting around on the water.
                    • 785boats
                      Wet Track Racing
                      • 3423
                      Beveling the front edge of the drive dog also reduces the water being forced up into the stuffing tube.
                      The bottom one is beveled. The top one is not.
                        Because the cable will shorten differently in each application due to length, stiffness, clearance in the stuffing tube, and load it is not possible to determine a perfect gap. Using washers between the strut and drive dog with no gap means that the cable will be in tension, causing excess drag and stress on the cable. As Tyler mentions above, a minimal gap is best, but you must not have the drive dog touching the strut.
                        I seldom have used one, but as mentioned a short piece of silicon fuel tubing on the inboard end of the stuffing tube can virtually eliminate water intrusion from the drive line, see below.
                        • properchopper
                          rcgoatbuild@snotmail.com
                          • 7708
                          [ATTACH=CONFIG]167501[/ATTACH]
                          Well I just learned a good tip - Thanks
                          In exchange , here's another method which works well to keep water from entering the joint between the stuffing tube and strut - cover the joint with siliconed-inside shrink ; has substantially cured water intrusion for me :
                          Here I had to notch the strut to allow the shrink to slip on :
                          • Capt'n Crash
                            • Mar 2015
                            • 166
                            I had a similar problem with one of my Pursuits with water entering the stuffing tube. All I had to do to solve the problem was change my method of greasing. After greasing the flex shaft I would put a couple pumps of grease from the gun in the stern end of the stuffing tube before inserting the shaft. Never had a problem after using that method. You do have to make sure to clean the end of the shaft of any grease before inserting it into the collet.
                            • martin
                              • 2881
                              As Paul has shown the bevel on the front of the dog helps prevent water being forced into the strut/stuffing tube. I have also been using this method for a long time now along with other usual mods to prevent water coming up the stuffing tube into the boat.
