Flex shaft help
  • Santig
    • Nov 2019
    • 79
    Flex shaft help
    Good morning gents. Could someone please direct me to a replacement flex shaft. The skunkworks 32 I just received has a busted shaft. Luckily I was wise enough to check it before running her. The flex shaft was sliping even with the coupling tight and the saver had a striped nut and had to remove the motor to pull it out the other end. It came apart where the metal peice conects to the shaft. I also think it has no stuffing tube .Here is the size I am looking for. Thank you in advance.
  • larryrose11
    • Jun 2010
    • 768
    I recomend Wholt RC.
    Strongest flex cable / stub I have found. I broke a lot of them, but a forum member suggested I get these, Never had one of theirs break.
    • Santig
      • Nov 2019
      • 79
      Thank you sir!
