Esc overheating
  • Damien
    • Dec 2019
    • 19
    Esc overheating
    Hi guys need help I got a 41? fightercat running tp4050 2000kv on 6s 60c new batteries 240a swordfish esc prop octura x447 3 blade problem is after 3 min boat cuts off when I check boat motor temp is good but esc temp is hot over 70 degrees Celsius what can I do to fix this thanks
    • 4340
    What type of running are you doing? Straight passes, ovals, partial throttle, wide open? What voltage are your cells at when you bring the boat back after 3min?
    • Damien
      • Dec 2019
      • 19
      Only a couple of hard straight line passes mostly half throttle ovals running after bringing boat back it?s 3.9v per cell
      • RaceMechaniX
        • 3024
        Running at half throttle creates a lot of heat in the ESC. Adding a small pump will allow you to sit for 20 seconds and let the ESC cool before hitting its thermal limit.
        Tyler Garrard
        NAMBA 639/IMPBA 20525
        T-Hydro @ 142.94mph former WR
          What Tyler said. But, the best solution is to severely limit any part throttle running. Three minutes is a lot of running for that motor/voltage/prop, you have an aggressive setup, run it like you stole it!
          • Damien
            • Dec 2019
            • 19
            Is the motor 2000kv motor to big a lower Kv will be better you think what about prop how can I lower temps with more run time
            • Alfa Spirit
              • 2183
              Octura X447/3 is a big prop for a 6S setup.
              X4442 or X445 should be better. Make test with aluminium or carbon propellers to find the best size.
              • Damien
                • Dec 2019
                • 19
                Thank you
                • martin
                  • 2881
                  An X447 3 blade is to much prop to be running @ over 44000 rpm unloaded.
                  • Damien
                    • Dec 2019
                    • 19
                    Yeah I?ll try a x442 also was thinking of a 2 bladed not sure
                      • 4340
                      For reference, I run a 4060 1750kV motor on 6S in a smaller, lighter 37" Genesis cat with an ABC 1915 prop (48mm 2 blade) and can only make 4-5 passes at wide open throttle before bringing the boat back with everything still in check.
