Prop suggestions 4082
  • njallday18
    • Nov 2019
    • 8
    Looking for prop suggestions for my new setup. I have a leopard 4082 2000kv on 4s with a seaking 180. This is on a 32 inch hydroplane. I have read that these motors can turn larger props but i'm quite ignorant, the selection is overwhelming Maybe the x447? Any help would be much appreciated! Thanks
  • MadProps
    • Mar 2017
    • 236
    I run 45mm or 46mm with that setup the 46mm I use is cut down and balanced and for the occasional 6s SAW run
    • HTVboats
      • Jun 2011
      • 936
      I would recommend an M445. M545 or ABC 1816 to start.
      Mic
      Mic Halbrehder
      IMPBA 8656
      NAMBA 1414
      • Capt'n Crash
        • Mar 2015
        • 166
        I've always been satisfied with an M445 with that setup on my mono hulls. The X series will give you better hole shot acceleration with slightly less top end speed. The M series will give you better top end speed but will slip a bit when accelerating out of the hole. The M series will draw slightly less amps as well. You will just have to try a few different props to see which suits your purpose best.
        • 785boats
          Wet Track Racing
          • 3423
          A Prather s225 is one of my favorite props on that sort of setup. Maybe even an s230 if things are running cool enough with the s225.
          https://www.offshoreelectrics.com/pr...i-prather-S225
