Hi guys, I am hoping for a simple answer but have found out in this fe business it is not always that simple.
Question is:
If I have a catamaran and running a 47mm diameter prop with strut height at 3mm above sponsons, then decide to run a 42mm prop (same brand and pitch) would I need to lower the strut 2.5mm? That would put the strut at 0.5mm above sponsons.
My rationale to this is that the 47mm prop is 5mm larger than the 42mm. Divide that 5mm by two and it gives you 2.5mm, hence that is where I have come up with the 2.5mm lower strut. Hope that makes sense, or have I totally gone off the garden path?
Question is:
and the reason to not move the strut?
