HiModel 4s-8s 200 amp esc
  • mappo
    • Feb 2010
    • 496
    #271
    himodel
    Turnigy Monster-2000 200A 4-12S Brushless ESC
    Any one familiar with this Esc from Hobby king?
    Do you know what the biggest problem with the world is?
    That the Smartest people are full of doubts while the stupid ones are full of confidence.::tt2
      I have one, not used it yet in a boat but, I've tested it.
      I think I had to play with my radio for it to handle throttle on my 3PM FM pistol. Thought I needed a Pi-Stix but, was able to set it up.
      The boat it is for isn't done yet.
      Very robust (big)
      • Lasse Baardseth
        • 76
        #273
        If you look at the FET's, some have extra solder where it looks like there should have been a gap between the different parts.
        Do you see what i see, or am i just to worried?
        • Lasse Baardseth
          • 76
          #274
          This is what i mean.
          • Jesse J
            scale FE enthusiast
            • 7818
            #275
            I have gotten pretty good coolers at a great price from Scotty (Skunkworks)
            Plasti-Dip works great and may be very similar to what Peter uses.
            "Look good doin' it"
            See the fleet
            • ksm2001
              • 397
              #276
              Originally posted by Insaniac
              Does anyone have any details about this cooling plate and the "liquid plastic" used to waterproof the HiModel ESC?
              Peter and I use Plasti-Dip, Steve sells it here on his site but I see he is out of it right now, we buy the product locally here from Home Hardware and it comes in various colors. When using it though paint it on with a brush, it will take a couple coats to seal all the parts.
              I use Peters cooling plates on my Himodel 200's and have to agree they are one of best.
              Ken
              DF-29,Phil Thomas Super Sport 45, SV27, Xzess 2 Evo, HOTR 32" Cat
              • NativePaul
                Greased Weasel
                • 2770
                #277
                I havent seen this thread for a while but now its back I thought I would update you on my luck with it on 8s, a couple of months ago I got all my electronics wet which was no problem for the ESC or RX as I waterproofed those myself but foolishly I trusted the MFGs conformal coating on the UBEC, to avoid that being the end to my day I removed the UBEC put the red wire back in the HiModel's lead and carried on running, I have now had about a dozen runs on 8s using its internal BEC and no longer plan on replacing the UBEC.
                • Jeff Wohlt
                  • 2740
                  #278
                  I bought a can of the spray version and will try it soon. I also think it is clear and not black.
                  www.rcraceboat.com
                  jwohlt5362@yahoo.com
                  • Alfa Spirit
                    • 2183
                    #279
                    I made water cooling with an ETTI plate, her is the result
                      Truly amazing when the fets are rated for 30Vdc ?? or at least someone said they were FDD8896 which have a 30Vdc limit...
                      Kudos sir.
                      8S1P or 8S2P?
                      • NativePaul
                        Greased Weasel
                        • 2770
                        #281
                        8s1p, I just looked at another one I have that isn't cooled or waterproofed yet and the FETs are FAG21AX FDD 8896.
                          Aaaaaahhh, thats different. You can only take so much from a single "P" setup and voltage decreases underload significantly on some 1P setups.
                          Any data from your runs by eagle tree, really curious to see what your underload V & continous current values are ??!!
                          • 785boats
                            Wet Track Racing
                            • 3423
                            #283
                            I've said it before somewhere (can't remember which thread) that todays ESCs use a voltage switching circuit for the internal BEC, as opposed to the old linear regulator circuits of a few years ago. They don't create anywhere near the heat being over 90% efficieni. Whereas the old regulator circuits were only 60%-70% efficient at best. They just got too hot with anything over 4s.
                            The Hi Model should have no problem dropping 8s voltage down to 5V.
                            I always use the internal BEC in all mine with confidence. Although I have never tried an 8s setup. Only up to 6s.
                            Here's a story that might interest some of you.
                            All the best.
                            Paul.
                            • Lasse Baardseth
                              • 76
                              #284
                              I just blew up two of the Himodel 200a 4-8s on 8s!
                              Both had DP270, etti coolingplate and etti capbank and i did not use the internal BEC.
                              The first just stopped after one day of racing, the second one blew up on pluginn.
                              The setup is Delta force 32" knockoff, 8s 5000, NEU 1521 1,5y prop prather 230 speed 58 mph.
                              The ESC was nice and cool all the time.
                              I think i might pushed it too far on my setup?
                              Next time i think i will try the Turnigy marine 240HV.
                              • 785boats
                                Wet Track Racing
                                • 3423
                                #285
                                Insaniac
                                The plates I make are 38mm X 35mm but you must make sure that they don't touch the blobs of solder on the three motor wires. They are extremely close.
                                Steve sells this one but note... it's on a 7s version where the motor wires are soldered on the rear board. But it should be fine on the 8s as long as it can't touch the wires. I also chamfer off the edge of the plate to give a bit more clearance & use a dab of epoxy on the corners of the plate so it can't move.
                                http://www.offshoreelectrics.com/pro...prod=etti-a044
                                Lasse.
                                Could the plate have touched the motor wires?
                                Cheers.
                                Paul.
