Boat turning problem
  • Ken_NJ
    RC Boat Addict
    • Sep 2013
    • 325
    This is a very odd problem I'm having. I have this Dumas Scarab I built back in 2014. It always ran with no problems. Recently I started having a problem with it turning. I'm using a Hitec DX4C radio with a Hitec SR410 receiver and Hitec servo. The boat would run fine with the normal turning radius, then all of a sudden the turning radius was almost nonexistent. Running at slow speed the boat would turn in a tight circle like it usual did. Sometimes when running at speed the turning radius would be fine then all of a sudden it was making a very wide arc. If I stopped the boat then startup again, the turning went back to normal for a short time. I swapped out the receiver and servo and the problem still occurs. The rudder moves freely. The only questionable thing at this point is the transmitter. Anyone experience something like this? Any idea what's going on here or what I can try to do?
    https://forums.offshoreelectrics.com...ghlight=ken_nj
  • MarkF
    dinogylipos.com
    • Mar 2008
    • 979
    Sounds like your receiver battery is going bad. What are you using?
    • Ken_NJ
      RC Boat Addict
      • Sep 2013
      • 325
      A 2000ma Nimh pack. I just checked it, batteries are at 5.21 volts after running the boat.
      • rol243
        • Apr 2017
        • 1038
        replace the rudder servo.
          • 7990
          I too think the issue could be the rudder servo. Exactly what servo does the OP have in the boat? I had a steering problem in one of my big 10S boats using a quarter analog scale servo. I replaced the servo with an identical one but the problem persisted. I replaced the servo with a digital model and the problem disappeared. The analog servo just lacked enough centering power.
          Other things to check include the condition of the plugs - the servo and the pack. And just because a pack shows decent resting voltage doesn’t mean it does so under a load. There isn’t much else.
          • MarkF
            dinogylipos.com
            • Mar 2008
            • 979
            Your Nimh pack could cause what your seeing but I would change your servo again with a new one and if that fails then change your receiver pack.
            • dasboata
              • Dec 2010
              • 3152
              Batteries or servo my money is on the batteries
              • Ken_NJ
                RC Boat Addict
                • Sep 2013
                • 325
                The original servo is a Hitec HS-485HB which has karbonite gears. The second servo I tried is an HS-322HD which also has karbonite gears. Already replaced the receiver. Next time out I'll try another battery pack.
                Hitec RCD offers precision servo actuators with superior engineering for airplanes, helicopters, boats, and robotics. Shop our proven selection today!
                https://servodatabase.com/servo/hitec/hs-485hb
                • bogieboy
                  • Jun 2018
                  • 219
                  i would run a servo with substantially more torque than any of those.... even my 23" vector i run around 200 oz-in. servo for steering... also ditch the NiMH reciever pack. i have good luck with my LiFe reciever pack in my Dumas DV60 running 2 300oz-in servos, one for throttle and one for steering.
                  these are the servos i run in my Dumas... https://www.amazon.com/gp/product/B076CNKQX4
                  more than enough to turn a 46" gas powered boat...
                  • Jesse J
                    scale FE enthusiast
                    • 7241
                    How to check the turning issue:
                    Power on everything as if you were going to toss it in the water, except don’t tape it up and you don’t need the esc powered up (safer for this experiment).
                    On the bench, try turning the rudder with your hand, it should be hard to turn. Watch your linkage, does it bend? If so, that could be it. Does it push or pull to turn right? I almost always have my big boats pull to turn right.
                    Next, if that test passes, try turning the servo with the radio and add resistance with the hand again, if the rudder is easily returned to straight without any mechanical issues, then a stronger servo, >300oz. If the linkage bends, add a carbon fiber tube around your linkage rod, or replace with thicker piano wire.
                    Please update with results of recommended experiments.
                    Jesse
                    "Look good doin' it"
                    See the fleet
                      • 7990
                      I too believe the servos are inadequate. I use stronger servos than those in my little P-powered boats. Gas boaters who run boats the size of the OP’s run a minimum 180 oz-in at 6.0 volts. My T boats ran perfectly with servos producing over 250 oz-in at 6.0 volts. Get more servo!
                      • Ken_NJ
                        RC Boat Addict
                        • Sep 2013
                        • 325
                        Found the problem. On the bench I held the servo arm in place and applied force to the rudder like Jesse J said. The push rod was solid and didn't see anything out of the ordinary. I removed the servo linkage to inspect it. Found a hairline crack in it on the side I couldn't see. Looks like the pressure against it while running the boat was enough to let it slip out while in a turn. Still seemed solid on the bench though. Will replace it and run it again, but not till the weekend.
                        • bogieboy
                          • Jun 2018
                          • 219
                          you will still have the problem if you are trying to run a 55" dumas scarab on a 50-60 oz in servo... the servo simply cant hold that much rudder... shoot, my first throttle servo in my DV60 couldnt even hold the throttle open (foot long cable in teflon sleeve on a short arm on the servo, and stock mounting point for the engine on the carb, and that was a 195oz in analog servo. go to a 300oz digital... it is well worth it....
                          • Ken_NJ
                            RC Boat Addict
                            • Sep 2013
                            • 325
                            This is not the 55 inch Dumas. Its the 45 inch hull.
                            • bogieboy
                              • Jun 2018
                              • 219
                              then we are in the same "boat" so to speak... a 60-80oz servo is nowhere near enough even for a 45". like i said before, my 45" dumas is running a 300oz servo for steering duty...
                              also, if you read the zippkits supersport 46" shallow v boat manual, they recommend at least a 150oz servo... http://zippkits.com/ssman.pdf
