Need help Weight questions?????
  • Eodman
    • 1285
    Ok 1st I have two mean machine hulls --- as we know 1 was set up with twin ep1's on the backend ... the new one I want to build for P offshore!
    I stripped the twin down --- burnt an esc up so i need to clean it up and make it look pretty!
    The older of the hulls weight 3lbs. 3 oz. and the new one only 2lbs. will that 1 lb 3 oz difference make a difference in speed & if so how much?
    The older hull is much stiffer so I think it will handle rough water better so my thought process says I should assemble that one with the 9 xl! My twin outboard is more for fun I'm not sure it will run in any of the classes but we'll see!
    Anybody have any thoughts?
    We did it with a Bang!
    Cats Are Where It's At!
  • Rex R
    • 1007
    I'd use the older hull for racing...you're gonna want the added weight/stiffness when racing. we don't often have a lot of say in the weather...that water can look like an ocean at times .
    rex
    • eboat
      • 726
      You could also look at it this way
      If you were racing and someone ran into you broadside which boat would survive better ?????
