External Ice water cooling system
  • Redfusion900
    • Jul 2019
    • 5
    Anyone thought of filling a cooler with ice water and running a small 12v pump with a y adapter to hook up to your pickups to cool the motor and ESC between packs and before a run? Curious of everyone's thoughts..
  • StevenBryant
    • Nov 2012
    • 366
    I believe a few people on OSE have tried this, from memory condensation was an issue with the esc.
    Sent from my iPad using Tapatalk
    • Redfusion900
      • Jul 2019
      • 5
      [QUOTE=StevenBryant;737519]I believe a few people on OSE have tried this, from memory condensation was an issue with the esc.
      Hmm.. being a supposed waterproof ESC I wonder how or where it would condensate. Theoretically it should be sealed from all internal condensation, in that case I would think it would be ok.
      • Bp9145
        • Jan 2016
        • 1466
        I usually have a large container/bottle of cold ice water and I just take a gulp and blow it into the rudder water inlet and watch it exit through the water outlet. Gets the motor and esc cooler but I do it slowly as in short bursts and let sit for about a minute before blowing more cold water. I don't know if it matters or not but I just don't want to cool it immediately. . . so by doing it in short bursts and letting it adjust slowly to the cold water I feel, imo, I don't shock my motor and esc if it even matters. I usually only do this when I have a bunch of kids waiting to get their turn or when I want to run that particular boat again and again. But I have 3-6 boats for the neighborhood kids to play with. . .lots of fun!
        • Peter A
          • 1624
          Why Ice water? Ambient temperature is sufficient. You don't even need a 12v pump, just use a 5 liter pressure sprayer.
          • Redfusion900
            • Jul 2019
            • 5
            Thats where I originally got the idea from.
            Agreed, I just figured I could use the ice water to lower the temps prior to the run. That is what we did when I was running snowmobile grass drag setups.. pre and after cooling with ice water. In our hobby It seems to be accepted that a cooler ESC and motor have less resistance that they do hot. Hence the ice water.
            • StevenBryant
              • Nov 2012
              • 366
              [QUOTE=Redfusion900;737520]
              Not all speed controllers are waterproof, if your running a fully sealed waterproof esc then condensation will not be an issue.
              • Peter A
                • 1624
                Yes but as soon as the boat runs again the ambient temperature water will just bring the temp back up and you could end up with the condensation issues. Don't forget that different metals expand and contract differently and the potential is there to create problems.
                  SAW racers do/did this, but after cooling everything we sealed the system since pond water would quickly warm things back up. It worked well without differential expansion issues, but this would not work for extended oval racing.
                  • properchopper
                    rcgoatbuild@snotmail.com
                    • 7708
                    That's just plain silly........
                    Oh Wait
                    • properchopper
                      • 7708
                      Here's another bright idea I experimented with (rather unsuccessfully) - fill tube with freezer pack blue ice, inline with onboard cooling setup to cool while underway. No bueno...........
                      Was relegated to the pile of other ideas that bombed such as the styrofoam turn fin & the edible propeller
                      • Bp9145
                        • Jan 2016
                        • 1466
                        Here's another bright idea I experimented with (rather unsuccessfully) - fill tube with freezer pack blue ice inline with onboard cooling setup. No bueno...........
                        [ATTACH=CONFIG]165868[/ATTACH]
                        Was relegated to the pile of ideas that bombed such as the styrofoam turn fin & the edible propeller
                        LMAO!!! I've done the same thing in the past and even worse ideas that I don't care to share. .LOL I'm glad I'm not the only "genius" in fe boating. .
                        • Bp9145
                          • Jan 2016
                          • 1466
                          LMAO!!! I've done the same thing, well similar, in the past and even worse ideas that I don't care to share. .LOL I'm glad I'm not the only "genius" in fe boating. .
                          • pescador
                            • 503
                            I use a USB powered submersible pump in a water bottle with ice, I run it with a small power pack phone charger. I only use it to chill the motor and it does an amazing job. I just got back from the Nats in Salt Lake and it got a good workout in the heat.
                            Namba District 16
                            1/8 Miss U.S., 1/8 59 Maverick, 1/8 Executone, 1/8 Smokin Joes, MLGSX380, AC Pro40II Q Sport, AC Pro40II nitro,Twincraft mono 10s, Vision AOPC, VS1 FE, M34.
                              • 4340
                              I prefer to liquid cool the driver.
