How to set drives at zero degrees
  • banixj
    • May 2012
    • 110
    Hello guys, acn you tell me if the procedure in the attached sheet is right or not?
    Thank you so much!
  • E36racer
    • Oct 2018
    • 11
    If I remember geometry correctly, that looks about right to me (not trying to be a smart @$$). But it has to be parallel with the flat surface below it to be 0 degrees. It does not matter what those 2 measurements are, just as long as they are the same it will be parallel.
