Need Professional Help.
  • BigJohnnyNC
    • Apr 2019
    • 7
    I purchased 3 new in the box Graupner Electro Vee Hulls.
    They are 28.5” long with a beam of 8”
    I need suggestions for a Brushless set up?
    I’m not looking for a racing setup, just fast enough to have fun with my kids.
    All three are going to be set up identical so we can race each other
    Motor size & KV
    ESC size
    Lipo battery cells, Mah & C-Rating
    Surface or Submerged drive
    Prop shaft size
    Prop size
  • stadiumyamaha
    • 1371
    In my opinion I’d set it up something similar to an aquacraft revolt.
    3656 2000ish kv
    Seaking 120 esc
    4s2p or a single 4s 50c plus
    Tfl stinger and rudder
    3/16 shaft
    442 prop
    Should rip, stay cool and be very durable.
    Jmo
    • Jesse J
      scale FE enthusiast
      • 7818
      Wow, that was my first FE boat!
      Are you going to use the steerable outdrive? This will make them quite squirrelly, but are cheap and relatively simple.
      A fixed strut or a stinger might be a better handling option. I’d be mounting it where the center of propshaft is 3/8” above the base of the vee, so it will be surface penetrating.
      The above recipe sounds reasonable. The boat can handle the weight. We used to use 12 round cells, a brushed motor on a 3:1 gear reduction and a 42-45mm prop. Probably got mid to upper 20s.
      With all the lift those hulls have, you don’t need a lot of power.
      I’d be more inclined to try a 2700ish 36mm motor on 3S2p with 40mm prop. And maybe go up to a 42 if needed.
      Maybe show us a picture of what you are starting with?
      If you ever want to sell those steerable outdrives, keep me in mind.
      "Look good doin' it"
      See the fleet
      • Speed3
        • Mar 2017
        • 371
        The revolt setup would be perfect for that boat.
        I would like to point out that the revolt motor is an 3656 1800kv motor.
        The x442 would be an excellent prop.
        4s lipo 5000 mah 20c or greater.
        Surface drive.
        • BigJohnnyNC
          • Apr 2019
          • 7
          I have a ton of 3S 5000 40c lipo’s from my airplanes!
          Should I increase the KV to use them or use them in series for a 6S setup & reduce KV?
          • Speed3
            • Mar 2017
            • 371
            You can run a single 3s with the suggested setup. The electro vee is a little smaller than the revolt and it probably have more lift. I would suggest 3s with the x442 or you can even get an m545 for 3s running with the suggested aquacraft 3656 1800kv.
