Ok setup?
  • J Lee
    • Jun 2013
    • 25
    Ok setup?
    I'm looking at putting a vee bottom together and want to make sure what I have will marry up well. I have an ML Boatworks 54" Fountain hull, a TP 5860 4Y 730kv motor, and Flier 300a boat esc. The hull the motor and esc were in ran 12s. Will this work well or be better suited to a different hull?
    Thanks
  • Jamey
    • Apr 2015
    • 199
    I think you should be on the right track. Only issue I see is 12S is going to be pretty hot with that kv motor. To keep the amps and speed in check you will need to drop down to a smaller prop than would be ideal for that big of a hull. You might do better at 8-10S depending on what you are wanting to do with this build. All out speed, sport, long run times, etc.
    • Jesse J
      scale FE enthusiast
      • 7241
      You got a pic of the boat, might help us evaluate, in addition to questions in previous post.
      "Look good doin' it"
      See the fleet
      • J Lee
        • Jun 2013
        • 25
        Thanks for the info so far. I had to lift this from Mike's site, so, sorry Mike.Screenshot_20190405-200414_Samsung Internet.jpg
