What size flex shaft do I need?
  • mnm99
    • Aug 2016
    • 48
    If I decide to remove the liner from my Proboat Sonicwake, what size shaft would fit good? Also what's the stock size? I can't find any info on it. I have been reading as long as I use good waterproof grease I shouldn't have a problem with water intrusion. Is this correct?
  • mnm99
    • Aug 2016
    • 48
    Is the shaft size .187 ?
    • 1coopgt
      • Feb 2019
      • 417
      You need to measure the inside diameter of the stuffing tube to figure out what flex shaft you need. You gave no info in your original post . How do you expect anyone to suggest what you need. Not trying to be a jerk but you are expecting people to remember what boat you have. I have no clue.
      • mnm99
        • Aug 2016
        • 48
        It clearly stated in my question. Read it again...... Is it Proboat Sonicwake. How much more info do you need? Somebody who owns this boat knows what size shaft it needs and anything else that I'm asking.
        • Capt'n Crash
          • Mar 2015
          • 166
          The stock cable is .187" in diameter with a 3/16" prop shaft. As suggested measure the inside diameter of the stuffing tube and experiment from there. Without the teflon liner it's going to be a lot easier for water to enter into the boat as the grease dissipates during the run.
          • 1coopgt
            • Feb 2019
            • 417
            Sorry I missed that .
            • Speed3
              • Mar 2017
              • 371
              The sonicwake shaft I think is .187. That is a decent size shalf for 6s.
              The boat probably can use a bigger shaft.
              As the inner tube may be bigger without the Teflon liner but the strut cannot take a 1/4 inch shaft.
              • mnm99
                • Aug 2016
                • 48
                Thank you.
                • RCBoaterGuy
                  • Dec 2014
                  • 203
                  Hey guy, I have PB Impulse 31v1
                  OSE store has two different cables for it..
                  Heavy duty (.150") with liner.. https://www.offshoreelectrics.com/pr...able-impulse31
                  Super duty (.187") with no liner.. https://www.offshoreelectrics.com/pr...e-HD-Impulse31
                  Steve also has a Super duty (.187") cable with no liner for your boat.. https://www.offshoreelectrics.com/pr...HD-SonicWake36
                  The common theme here is: cables with liners are .150", cables withOUT liners are .187".
                  Suggestion: remove your cable & measure the diameter with a micrometer; if .150", then I think it's safe to say that without the liner it will be .187" - if it's already .187", then you have your answer.
                  HOWEVER, to be on the safe side.. I would contact Steve(OSE store) and ask him to confirm if I'm right or wrong.
                  If you use a good grease (see attached), water intrusion will be minimal - I think some is going to get in no matter what you do. Trick is to minimize it.
                  Hope that helps to get you going in the right direction.
                  AQ MiniMono - CopterX 430XL 3550kv BL Outrunner + Seaking(V2) 35A on 2S VERY Fast
                  Pro Boat SW26v3 - 2860-2600kv + Seaking(V2) 90A on 3S, Build in Progress
                  Pro Boat Stealthwake 23 - Stock For Now - Brushless Down The Road
