Delta cyber storm 33"
  • nitrous8e
    • 30
    Delta cyber storm "33" what would be a good fast and reliable motor esc. Setup? This will be used for " p" class ' 4s .. I am not looking to set world records
  • Thunder29
    • Apr 2017
    • 155
    seaking 180amp esc / TP 3650 2350kv. It's a great setup in my 32" HK Outerlimits on 4/5S.
      More reliable would be slightly less kv, around 2000kv. Above motor works well but it's fairly hot for a P mono race setup imo. The higher the kv for that class the more time you need to get it setup right as not to pop an ESC.
      Not pulling punches Thunder but do you race that on 1 mile ovals? If you do, Kudos sir.
      • Speed3
        • Mar 2017
        • 371
        Tp 4060 1950kv, a good 4s battery, 45 to 47mm prop (m545, m447 just to list a prop or two).
        The swordfish 220 x would be a good ESC.
        • rol243
          • Apr 2017
          • 1038
          yes i bought one of these hulls running on a t.p. 4060 - 1950 motor . 180 esc , 4s 1p. goes very well.
          • Thunder29
            • Apr 2017
            • 155
            My temps come off around 115 on a 4-5min run. I Have run duel 5s in parallel on the seaking 189 with tp 3650 2350kv motor with 8min run time and still motor temps were in the 110-115.
            • Jesse J
              scale FE enthusiast
              • 7818
              How cold was the water?
              "Look good doin' it"
              See the fleet
                It's airing right out with that light motor Thunder. Have you run it on 4s in traffic?
                • rol243
                  • Apr 2017
                  • 1038
                  yes 2350 kv,s on 5s is pushing it abit in oval trim.
                  • Thunder29
                    • Apr 2017
                    • 155
                    I'm not sure of the water temp. It was Fall / Late Fall. So the water was definitely not summer temps. Also was propped fairly conservative with a 3 blade 40mm/1.4pitch
                    Also just running with 1 other boat so no real traffic. I would agree this is probably not the best setup for racing. However it does work pretty so i was just putting it out there.
                    I suppose if you are going to run it in oval then it's all about the setup and driver comfort.
                    • 785boats
                      Wet Track Racing
                      • 3423
                      I raced mine in our 4s EA class, with a TP 4082 2200kv motor; Seaking 180A ESC, & an X440/3 prop. She went ok.
                      • Sizemore
                        • Nov 2018
                        • 7
                        Delta Force Build
                        Building a Mono P Limited with a DF Cyber Storm hull. Have a seaking 160a ESC with 2 5000 Mah 14.8V batteries in parallel. What motor should I use for this class that will be competitive? I purchased a Auqua 3656 2030KV, I was told the rules call for 3656 size motor. I know there is a lot of tuning to the boat itself with fins, planers, and moving the center of gravity. I just would like to know that I have electronics to be competitive. Also does the size of steering fin make a difference in handling or speed?
                        I keep seeing the RPM's should be around 30000, should I adjust my timing in ESC to set my RPMs to 30000, and from there choose the best prop?
                        • jaike5
                          • 564
                          Keep the batteries in the centre of the boat in front of the motor, in my storm cog is at 36%. I use dual water pickup rudder, and medium rectangle turn fins, tear drop fins are not as stable imo. Fins and rudder I bought from ode.
                            Speedmaster fins Jay?
                            • jaike5
                              • 564
                              Hey Ray, the fins are from ose, $13.95 with mounting hard ware,
