M/l boatworks 1/10 scale hydroplane build 121
  • meangenesracing
    • 1332
    Originally posted by RON F View Post
    Hi There the foam for buoyancy, good idea but can I use foamofil ? Or is the foam somthing special?
    Ron, what I use is green foam board you can get a 2ft. X 2ft piece at Lowes for cheap. I ut to fit in each space under decking. Cut to shape fill to top however pieces you need and use a jack saw blade to level to top works perfect in my own opinion
    • RON F
      • Nov 2018
      • 27
      Yup I'll do that, it's probably better foam than fomofil too
      • 785boats
        Wet Track Racing
        • 3423
        Hi Ron.
        I used 2 part eco foam in that pic. But in my last few builds I have just been using that white coolite packing foam. Like in the pic below. But any lightweight foam board will do.
        Expanding foam can cause problems by expanding more after the decks are added on. And sometimes shrinking and sucking in the skins & ridepads, leaving hollows between the framework. That has happened to me.
        Here's a pic with the white packing foam.
        • RON F
          • Nov 2018
          • 27
          Hi there do you glue it in or its just held in once the top deck goes on?
          • meangenesracing
            • 1332
            I don't glue mine I just pack it in tight
            • RON F
              • Nov 2018
              • 27
              Hi there
              I am waiting for some finishing epoxy to show up I have cut foam to fit and should soon be ready for the top decks, do you use a thin paper board to make patterns for the top decking?
              • 785boats
                Wet Track Racing
                • 3423
                I simply lay a piece of butchers paper over the frames of the panel I want, & crease the paper along the edges of the chines, frames, stringers etc.
                Then draw it a bit bigger and cut it out. Mark it out on the ply & then cut & trim to suit.
                Here's what I mean with the paper & the creases.
                • RON F
                  • Nov 2018
                  • 27
                  Ok good idea I will do it that way thank you. This boat, a vintage 60s hydroplane, I Plan to run it in a club, up in the pacific n.w (classic thunder) in a vintage class, it's supposed to go counter clockwise, what rudder assembly would you recommend? I got in on a club buy and have a scorpion brushless motor coming for it but i have no internals other than that so far.
                  Regards ron
                  • 785boats
                    Wet Track Racing
                    • 3423
                    If you are going to race it in a club, there are certain rules governing strut,motor, turn fin etc. As I've never set up a left turning 1/10 scale hydro, I cant offer any definitive advice.
                    All I can say is that for the ones I've built, for right turning, I've used the Speedmaster 20 strut and rudder.
                    The other guys on this thread, and forum, will be able to help you. Some of them race 1/10 scale.
                    They'll chime in shortly, I'm sure.
