Aquacraft EP1 outboard motor
  • ice_spy
    • 136
    HULL:-
    Robbe Prinzess 25" sport V hull ABS boat.
    IDEA:-
    just purchased an Aquacraft EP1 and a 36x55 metal GrimRacer prop.
    Plan to put an eXpress motorsports brushless 13.5T , ( i think the specs are; 3300kv 195W ) motor in it.
    What would be a suitable ESC?
    ebay has a mystery 100amp constant 110max for very cheap, are these any good? would this handle the 13.5T?
    I have an IP 3800 2S 25c+ 7.4 pack i wish to use from my touring car.
    Are the 36x55 GrimRacer props a surface drive prop? as i will need to set the motor up at the right transom height.
    I just want to have some scale fun and hope to get good hole shot, with half decent top end speed.
    Any help by anyone would be much appreciated.
  • crazzy maxx
    • Dec 2007
    • 498
    i dont know if the gears will hold up to a brushless system...
    snort pixi sticks=symptoms-:
    • ice_spy
      • 136
      Thanks for your reply maxx,
      I was thinking the same thing, but i will see how they go, Aquacraft have spares for the EP1, so at worst i will just replace the gears and go back to a slower can.
      • kck741
        • Aug 2007
        • 282
        I honestly think it will be able to handle the power,
        S.S.R.C-Southern Style Radio Control
        • Ocean Racer
          • 511
          From what i have heard you have to watch the gears. They can take the power for a couple of runs depending on how you use them. I remeber reading how to mount the motor. Ok right above the prop there is a plate that goes the full length of the outboard. You have to make that level with the bottom of the boat. Thats what they said for the best performance its in side a manual that i think comes with the EP or the Pro Fisherman.
          Failure is the First step to SUCCESS
          • ice_spy
            • 136
            Thanks ocean racer, yep the cav plate, know a bit outboards from growing up with real boats and outboards, thats why ive choosen to set up soomething simple first, then work my way up to something faster and an outdrive as my knoweldge grows.
            The only thing im not sure of is:-
            Is the GrimRacer 36x55 a surface prop?. An old friend i dont contact anymore ran a real life race ski boat, with a 175merc outboard, runs a bullet cone on the gearbox with a surface drive prop. Freekn you should see the rooster and revs from this thing!, but yeah im sure i remember him saying he had to jack his motor up a bit to better suit the surface prop.
            • crazzy maxx
              • Dec 2007
              • 498
              in my race boat i trim up jack up until im just about to loose water pressure...(race boats w/ my dad)
              with the rcs i burry the jack and trim it up and its gets going
              haveing a roostertail = increased prop slip = lose of speed.
              • kck741
                • Aug 2007
                • 282
                wow wouldnt it be cool to have a servo trim the outboard as you get up on a plane like on the real thing
                • ice_spy
                  • 136
                  now that would be cool!!, thanks for the idea kck741, might have to look into that!
                  crazy max, that sounds about right from what my mate used to do. he bought the X race boat just to go fast and show off. lol.
                  • crazzy maxx
                    • Dec 2007
                    • 498
                    lol
                    i have been looking to find a way to do that for a while now... when my rek o/b comes in the mail (told me 3 day shipping its benn 2 weeks still now lower) im gona try it on my ts2. there ius a way you can limit servos right?
                    • Diegoboy
                      • Mar 2007
                      • 7444
                      You may be interested in this device.
                      • crazzy maxx
                        • Dec 2007
                        • 498
                        that maximuzes servo rotaion
                        • calcagno45
                          • Mar 2008
                          • 1050
                          And you can limit the endpoints with it also, just turn the screw the opposite way.
                          My prop hasn't been wet in a while.
                          • Diegoboy
                            • Mar 2007
                            • 7444
                            That is correct!!
                            • calcagno45
                              • Mar 2008
                              • 1050
                              Or you can use a Tx/Rx other than a simple stock AM that has endpoint adjustments on it.
