Neu 1515 2y/f/h
  • greenblast
    • 301
    Neu 1515 2y/f/h
    I bought this motor thinking it was a d wind but it is a y. Is there a hull it would push with 8s. I was going to run it on 4s2p thinking it was 2200 kv but it is 1100kv. Any thoughts would be greatly appreciated thanks greenblast
  • RaceMechaniX
    • 3024
    Run it in a normal 4 cell boat but instead of 4s2p run it connected as 8s1p with an appropriate controller.
    Tyler Garrard
    NAMBA 639/IMPBA 20525
    T-Hydro @ 142.94mph former WR
    • greenblast
      • 301
      Cool. Thanks for the info. Would it swing the same size prop as a 4s neu?
      • Nevs
        Sven
        • Sep 2011
        • 165
        Its not completly true. But a "Honda" 600 cc /50 kw motor would be the 4s2p. The "Harley" with the 1200 cc/ 50 kw would be the 8s1p. So yes it would swing the same prop.
        • RaceMechaniX
          • 3024
          Prop it the same. Something in the 40-44mm range is a good starting spot.
          Tyler Garrard
          • greenblast
            • 301
            Thanks for the info! So i think i get now high kv =1/2 volage double the amps double the volts=1/2the amps both give the same watts. Now i need to figure what hull. i was going to resurect a old meanmachine with the 4s set up.I also have a miss vegas it would bolt in.
