Castle 2028 800KV Amps
  • davelc56@gmail.com
    Capt. Dave
    • Oct 2018
    • 28
    Hi. Has anyone checked the current draw of this motor, on 6S up to 12S ?
    Can't find the info anywhere. Thanks!
    Trying to choose an ESC.
    Where can I get a 6V 3+A, BEC for a 12S battery?
    Thx again
    Capt. Dave
    • Oct 2018
    • 28
    Also, what does "1Y" refer to?
    • Nevs
      Sven
      • Sep 2011
      • 165
      6s. The new hobbyking120- 160 A, (do not know it)
      8s. Yep 120 A, (great ESC.)
      10s. Swordfish 240-300 A + (flier+++).
      12s. Flier 16-24s. esc. 400 A
      • RaceMechaniX
        • 3024
        The 2028 will run right around 200-225A on 8S with a competitive prop load for heat racing.
        On 10S I was logging around 250-310A consistently using an MGM40063.
        I would not advise running the 2028 on 12S in a boat. Just too much load.
        Tyler Garrard
        NAMBA 639/IMPBA 20525
        T-Hydro @ 142.94mph former WR
          Capt. Dave
          • Oct 2018
          • 28
          Thx Tyler. Great info. Looks like that 180A is a little light
          Just looked up that ESC. $860 Euros? Can that be right?
          Swordfish 300 Pro HV sound OK?
          How do you power Rx and servos?
          Cheers
          • RaceMechaniX
            • 3024
            Yeah, the MGM's are not cheap, but you are talking about 12kW of continuous power with logging and safety built in to protect from frying an expensive controller.
            Although I have not tested the new SF300 Pro HV, I have heard good reviews from several guys I trust.
            I recommend to skip using a BEC even if the ESC has one and use a physical switch and RX pack to power the receiver and steering servo.
            Tyler Garrard
              Capt. Dave
              • Oct 2018
              • 28
              OK, good advice. How do you handle the common grounds? (Rx and ESC)
              I need advice on antenna's. Are todays ground TX's on 2.4 GHz like aircraft? They use twin antenna's? I just haven't got to the research yet.
              Thx
              • RaceMechaniX
                • 3024
                On the ESC just remove the red or middle wire from the 3 pin receiver connector and tape it out of the way. Don't cut it as you will likely need it for programming.
                For the receiver antenna, on most ground systems like Futaba there will be an internal antenna and an external one. You want to have the external antenna outside the boat and pointing vertically.
                On the modern 2.4GHz systems, the last 1" is what needs to be up in clear air. If the external antenna is too short, various companies sell longer antenna which you can exchange.
                Tyler Garrard
                • maxxximatoze
                  • Jan 2017
                  • 8
                  When you say 250-310A on 10S with an MGM40063, it was for how much time (a few seconds, minutes, a full 10000Mah pack...) ? How was the motor shape after this run between 10 to 12kW of input power ? how was the temp ? Do you think it can cope with these running conditions with good reliability ? Thx a lot !
                  • RaceMechaniX
                    • 3024
                    This was a heat racing set-up so it was only intended to run 7-8 laps maximum. The motor did get warm, but not hot. If I ran longer and used more capacity it would likely damage the motor.
                    It cannot run at these conditions for extended periods.
                    Tyler Garrard
                    • zooma
                      Local club FE racer
                      • May 2014
                      • 653
                      Hi guys. I use a 3" extension with the red wire removed. Therefore I don't mess with the connector on the ESC.
                      Ron - The Villages, FL
                      • maxxximatoze
                        • Jan 2017
                        • 8
                        OK thx for the info !
                        • maxxximatoze
                          • Jan 2017
                          • 8
                          I think that with a constant current between 250 and 310 amps for 7 to 8 laps and keep it under 80°C is already a performance... Do you know the phase resistance bullet to bullet of the 2028, I can't find this info anywhere. In fact there is two infos that I can't find, I0 (no load current) and Ri (phase resistance)... Thx !
                            Castle does not release amp ratings or resistance values to the public.
                            https://forums.offshoreelectrics.com...kv-motor-specs
                            • maxxximatoze
                              • Jan 2017
                              • 8
                              I know that castle does not release any spec about motors and esc, it was in case that you have measured these values. I've done these measures, for example, on the losi dbxl-e stock 800kv motor, Ri is 5.8milliohm (at bullet connectors) and I0 at 32V is 4.2A. With these values you can calculate or graph the efficiency curve and have a good idea of the motor behavior at a specific current level (execpt for the iron saturation max current).
