China outrigger
  • emspjay
    • Sep 2017
    • 411
    China outrigger
    Anybody build one of these yet?
    https://www.ebay.com/itm/New-RC-Outr...r=472206537675
  • raptor347
    • Jul 2007
    • 1177
    Build a JAE/Keps/MLB. The end product will be a much better boat.
    Brian "Snowman" Buaas
    Team Castle Creations
    NAMBA FE Chairman
    • enzo thecat
      • Jul 2013
      • 42
      Those color choices get expensive!
      • raptor347
        • Jul 2007
        • 1177
        It actually looks like a copy of the old Climate riggers.
        NAMBA FE Chairman
        • rol243
          • Apr 2017
          • 1038
          Hobby King used to sell a small rigger like that one. hollow sponsons too.
          • emspjay
            • Sep 2017
            • 411
            Never had a rigger before unless you want to call my vintage Graupner Tornado one? It looks close to the idea. I was originally thinking a JAE33 or ML380 but was thinking maybe I should start smaller? Or should I just pull the trigger on a big rigger? I just run for fun but have a need for speed.
            • raptor347
              • Jul 2007
              • 1177
              You'll find the larger boats run better and not much more to rig.
              NAMBA FE Chairman
              • martin
                • 2881
                If you want a smaller rigger to start with look @ the Zippkits Mini sprint, they are very cheap to kit out & they run superbly well indeed.
                • NativePaul
                  Greased Weasel
                  • 2770
                  Or the 17" RBC Fast4ward which is a bit lighter on its feet and less thirsty than the 18" JAE Mini Sprint if you favour runtime over speed. Both are good and quick boats.
                  • aj34me
                    • Oct 2012
                    • 52
                    Joe at Zippkits is very close to releasing a new 26FE rigger. We have been testing it for the past few weeks. It is a fit between the Mini Sprint and the 33FE. On 3s power with a 28mm or 29mm motor we are getting 50 to 55 mph in heat racing trim. It is virtually the same size as the .12 Nitro rigger.There is ample room for any battery combination you might want to use. It is like all other JAE (Zippkits) boats. It is a quality boat with outstanding building instructions. Plus, it doesn't break the bank to build! You will be very happy with this kit.
                    • jim82
                      • Jan 2013
                      • 1358
                      I have a Jae12 now I built for Fe very fun a and fast with a Tp 2940. 67mph and has more in it once I get a chance to go back to the pond.
                      • aj34me
                        • Oct 2012
                        • 52
                        Sounds outstanding.
                        • aj34me
                          • Oct 2012
                          • 52
                          Jim, what KV are you running? And, is that on 3s power? Prop? Thanks
                          • 785boats
                            Wet Track Racing
                            • 3423
                            emspjay.
                            I would agree with the others here. A larger rigger would probably be better.
                            But in answer to your original question. Yes I've built one.
                            I built it to mount a ducted fan on top of it. But as with a lot of my projects, it was shelved & not finished. I'll get to it one day.
                            But here is the basic structure if it is any help.
                            https://www.rcgroups.com/forums/show...5-HK-19-Rigger
                            • jim82
                              • Jan 2013
                              • 1358
                              Tp 2940 2800kv on 4s with ABC 1514-17-45
