Hatch tape
  • lomdel
    • 722
    Hatch tape
    What, besides OSE's Hatch tape, do you guys use to seal your boats before runs. I've read that electrical insulation tape would also work, that true?
  • video200
    • 840
    alot of tapes works. but i have found that most of them tend to leave some resedue when you remove it again. but in a pinch everything that keeps it dry works.
    • lomdel
      • 722
      What does not leave a residue?
      • video200
        • 840
        for one the OSE hatch tape
        • calcagno45
          • Mar 2008
          • 1050
          yep! hatch tape(hockey tape) peels off cleanly.
          My prop hasn't been wet in a while.
          • Tony
            • 420
            It took some paints off my boat hull as well.
              • 7512
              Good quality (3M) electrical tape works for me. Lots of colors to match with the boats I have.
              Never any residue.
              • Jimmy Sterling
                • Apr 2008
                • 417
                3M also do a clear tape that works very well and leaves no residue
                Come to the FASST side
                • JimClark
                  • 5913
                  Then the hull probably wasn't prepped correctly or the primer and the paint do not work well together. I know that one as I just stripped my brand new 1/16th scale hydro down to bare wood as the paint did not bond well with the Krylon rattle can primer I used
                  Billy Graham
                  • ace028
                    • Aug 2007
                    • 986
                    I use 3m clear electical tape from walmart, its like $2. Leaves no marks, unless you leave it there for a few weeks. I use this because if I run out, I just go to walmart which is close to where I live, and plus the wife likes going there anyways.
                    Twin power =
                    • Raydee
                      • 1619
                      The best tape I have used so far is Andover hockey tape. It is sold only at Great Skate hockey stores but I was lucky enough to find a guy with a bunch of cases and I bought them all
                      It is basically the same as the Renfew stuff that Steve sells but is less sticky. It won't peel the paint off even a poorly painted hull but still seals great and is very strong. The best part is it is very stretchy and will tape even the most stubborn curved hatch like a champ.
                      Team Liquid Dash
