phil thomas ss45
  • madmikepags
    • Aug 2012
    • 1371
    My really hot prop is a prather 250 cut down to 56mm and cupped. VERY HOT PROP!!!
    We call ourselves the "Q"
    • Navherc130
      • Sep 2013
      • 151
      Very well. Thanks much for the input, madmike
        • 9481
        Looking forward to this one, I've never thought of running a lower KV like this for Q
        • rol243
          • Apr 2017
          • 1038
          It does work. lower kv equals more prop and pitch as opposed to higher kv,s that require smaller props .
            • 9481
            never said it didn't
            lower KV takes a bigger wheel
            I'm setting my P Hydro up with a much lover kv than I thought I would ever race with running a very big prop with help from Darin
            as opposed to my picture (upper left)running high KV that got me 1st
            • ETOWNE
              • Mar 2008
              • 299
              I’ve been running mine with 1527 1y (1250kv) with a x452. Temps are around 110 after a mill. I was using single 6s 5000mah 60/120c. Started ever so slightly puffing cells. Went to graphene 6000mah and I’m good. Trying x455 this weekend. With the 5000 mah I was right at 65 mph. Dropped the strut a little and put 6000 mah in and was just over 70mph 3-6” of chop, it was hard to hold on to. 5328 watts on that run. Gonna try x455 and x648 this weekend. Maybe parallel 2 5000mah and see if it picks up more from less voltage drop.
              Vortex 22 hydro ammo 36-50
              Vortex Cyber Storm 33 P spec Mono AC 36-56
              PT SS-45 Q-hydro Neu 1527/1Y
              • rol243
                • Apr 2017
                • 1038
                the 648 might be abit small as opposed to the 455.
                • ETOWNE
                  • Mar 2008
                  • 299
                  I’ll start with 648 then 652. Not trying to cook it
                  • rol243
                    • Apr 2017
                    • 1038
                    I am also setting up a new 6s sport hydro with a 1250 kv motor, props to test will go from x450 / x452 / x455. a club mate has the same set up and he runs a prather 245, all is cool after a race .
                    • ETOWNE
                      • Mar 2008
                      • 299
                      Ya, that’s what I did. Started with x448. It ran hotter than 450. Think over revving maybe sending voltage back to speed control. I’ve read that Prather 245 is good but I have 0 experience with them so, I stay with octura. The x452 works good and isn’t cooking stuff. Sharpened and balanced is all I did to it.
                      • rol243
                        • Apr 2017
                        • 1038
                        you might end up using the x455 like me.
                        • ETOWNE
                          • Mar 2008
                          • 299
                          You’re pry right. I keep putting more weight on front. You running front wing?
