Burned up speedcontrols
  • U.L. HYDRO DRIVER ICE
    • Apr 2008
    • 265
    I have burned up two 100 amp speed controls (x power) with this set up 2700 kv L series 2 pole motor , 440 octura prop , two 3s lipo in parallel 2200mah each 30c each , motor temp was fine 85 degree batteries were fine and the speed control was getting 150 degrees before we burned them up on only minute run time
  • ReddyWatts
    • 1700
    FeCalc estimates this setup would use 100 amps in a cat hull and 110 amps in a mono.
    ReddyWatts fleet photo
      • Apr 2008
      • 265
      Why is the motor staying cool and speedcontrol heating up and I ran the aquacraft speedcontrol and ran fine thanks
      • ReddyWatts
        • 1700
        The motor is only using about 900 watts. Steven recommends not using more than 70 amps on the X-power 100 amp controllers.
        70 amps constant, 100 amp max.
        The aquacraft controllers seem to handle a lot more than they are rated. I have read some users are running 540 9XL's on them.
