Sea king 180 v3 ESC
  • 30nitro
    • Feb 2018
    • 330
    Sea king 180 v3 ESC
    Hi all..... Are we finding it better to use an external BEC and batt on this esc...to avoid heat and LVC issues....say..on a 40/92. 1900 kv on 5 or 6s..... Already added another cooling line..... Or ....run as is....? Thanks...
  • Prodrvr
    • Jul 2015
    • 701
    I run a separate battery and add an 8800uF cap pack to it.
    • 30nitro
      • Feb 2018
      • 330
      In addition to the factory cap bank..?
      • Prodrvr
        • Jul 2015
        • 701
        Yes sir
        • Prodrvr
          • Jul 2015
          • 701
          But I run hot setups...6s 2200Kv.
          • 30nitro
            • Feb 2018
            • 330
            And that's workin out good for you..? Nice... ..Thanks for the info..
            • Prodrvr
              • Jul 2015
              • 701
              So far, yes.
              • emspjay
                • Sep 2017
                • 411
                I put a EBEC on one of my SK 180 and have been running 4082 1600KV on 6s with no problems. Did that from the start after upgrading from the 120 I burnt up to the 180, why risk burning a expensive ESC when the EBEC's are cheap.
                • stadiumyamaha
                  • 1371
                  Been a while. To confirm, you just pull the red (pos) pin from the esc to receiver plug?
                  • Prodrvr
                    • Jul 2015
                    • 701
                    Just the red
                    • TRUCKPULL
                      • 3293
                      Yes. But I use a 3 in. servo extension. disconnect the red wire in the extension. Then you still have a good connection point when you want to program your ESC.
                      I also do this in twin setups, I use two extensions connected together with the red wire disconnected at the radio end.
                      Larry
                      • Prodrvr
                        • Jul 2015
                        • 701
                        Not necessary on the SK180
                        • TRUCKPULL
                          • 3293
                          How is it NOT necessary if you use a program box to program your ESC's and use a receiver battery or a U-BEC?
                          Larry
                          • stadiumyamaha
                            • 1371
                            Good call. I used to do that but forgot about it.
                            • Prodrvr
                              • Jul 2015
                              • 701
                              Larry
                              The SK180 has a separate connection strictly for the program box. There's a wire from the box that plugs into the top edge of the esc.
