new to boats I have a prather 46 in deep v I would like to make electic it has a castle mamba xl has surface drive with 1/4 cable so I bought a leopard motor 56110 in 780 kv I would like to run it on 8s with a octura x462 prop the motor has 6 mm bullet connectors and the speed control has 8mm which should I change motor or control iknow nothing about electric thanks for any help limited income
prather 46
I would use the castle 8mm connectors they are rated up to 300amps.Originally posted by fastastro View Postnew to boats I have a prather 46 in deep v I would like to make electic it has a castle mamba xl has surface drive with 1/4 cable so I bought a leopard motor 56110 in 780 kv I would like to run it on 8s with a octura x462 prop the motor has 6 mm bullet connectors and the speed control has 8mm which should I change motor or control iknow nothing about electric thanks for any help limited income
I think your setup should be right on the money as long as the boat doesn't weigh a TON. Use 8mm connectors, bigger is better. Is the speedo a mamba XL2? the first editions had problems like blowing up on plug in!!!!!We call ourselves the "Q"
Cheap and big boats do not usually work well...what capacity are your batteries...8S will be plenty for messing around speeds. Hope you have a recovery boat as well if you are running on a river. 6S will work as well and may be your friend as it will be slower and more stable on the river.
I have the exact same motor on 10S in a 45" mono and its about 62 MPH in oval race trim.Grand River Marine Modellers
