8s build help
  • Crash
    • Oct 2015
    • 313
    8s build help
    hi guys.
    I am thinking of a new set up for my hull, its just for fun. not racing it.
    im new so looking for your help and suggestions.
    the boat is a 36 inch by 11 inch mono fiber glass
    motor would be a leopard 4082 or 4090 series... KV rating?
    thinking of the 240 or 300 swordfish ESC?
    two 4s 6000mah 65c ?
    size bullets?
    Thanks guys
    Dan
  • StevenBryant
    • Nov 2012
    • 366
    I would run
    Kv = 1200 ish
    Motor = NUE 1527
    Esc = 300 amp
    Connectors = Castle 8mm
    • Crash
      • Oct 2015
      • 313
      Originally posted by StevenBryant View Post
      I would run
      Kv = 1200 ish
      Motor = NUE 1527
      Esc = 300 amp
      thanks. Is there a lower budget motor you like?
      • Crash
        • Oct 2015
        • 313
        so I am considering going 6s to 8s
        will the 8s set up be faster over all or the same being that I would be keeping rpm near the same and running same props? what is the advantage of more volts to the same boat hull?
        • Crash
          • Oct 2015
          • 313
          am I better off buying lighter hull aka carbon fiber 33 inch mono and keep my 6s set up for that hull to go faster..????
          • StevenBryant
            • Nov 2012
            • 366
            The higher the voltage the less the amp draw for a given motor. Watts = voltage *amps (ampsmps = watts/voltage)
            Sent from my SM-T280 using Tapatalk
            • StevenBryant
              • Nov 2012
              • 366
              Yes Leopard
              • StevenBryant
                • Nov 2012
                • 366
                Difficult to answer as I don't know your current hull setup
                • Crash
                  • Oct 2015
                  • 313
                  so I could run same props with less amp draw or larger prop with same amp draw?
                  • CraigP
                    • May 2017
                    • 1464
                    You can run the same prop, at the same rpm (motor KV change) at lower amps with higher volts. Of course, a larger prop will pull more amps. The big mistake people make when increasing voltage is they don’t change the motor to a KV that will produce similar RPM as the original setup. Trying to turn a motor with a KV for 4s on 8s, is a formula for disaster.
                    • larryrose11
                      • Jun 2010
                      • 768
                      The other advantage of higher voltage / less amperage is less heat generation.
                      Power dissipation (heat) = current^2*resistance.
                      I recently burnt up a motor / controller from too much heat. Luckly, the boat is fine. Smells funny still. it was a 3100 KV motor on 3S (It came that way) .
                      The new setup is 1680 KV on 6S.
                      • CraigP
                        • May 2017
                        • 1464
                        Larry is dead on! I’ve got 1700kv motors in my 6s boats.
                        • Crash
                          • Oct 2015
                          • 313
                          Awesome info guys!
                          rite now my lipos (3s 6000mah 50c)don't want to keep up with the props I am trying and boat will not perform as it should with its stock prop size....(proboat Voracity / stock prop 645 / 50 mph) I am seeing 42 mph max on that prop. I switched out stock motor (1650 kv) for 4090 1730kv and switched out 120 amp ESC to a 220 amp esc
                          • Alfa Spirit
                            • 2183
                            You can run :
                            1500 kV 4082
                            180A esc (HobbyWing)
                            2 x3S batteries 5000mAh or 6000mAh
                            Budget motor : TFL SSS 4082
                            • Crash
                              • Oct 2015
                              • 313
                              what lipos do you use with this set up, I have a similar se t up now.
                              I have two sets of 3s 6000mah 50c that can not keep up and two have puffed up.
                              I have one set of 3s 5000mah 70c they do better but still see a drop in voltage to 19.0 v and amps up to 350 @ 100% throttle
