8s build help
  • Crash
    • Oct 2015
    • 313
    #61
    Originally posted by Prodrvr View Post
    Afraid of what?
    I assumed he meant afraid of going to fast with the Voracity hull.
    this hull is couple years old and has been reinforced with FG threw out hull.
    Afraid of 8s ? NO, its awesome . I tried 5s recommended from the info and advise here. I tried 6s and then tried 8s. its true once you go 8s you don't go back. lol
    its a animal like I wanted, yes its over powered for sure. Ran my 52mm prop today for fun to see the data and it ran killer...this hull loaded is over 10 lbs and it jumps out of the water like a rocket and does not stop until you get scared and back off throttle.
    all that fun at and amps are good, temps are good …….
    • Alfa Spirit
      • 2183
      #62
      Afraid of what?
      The hull is a 36'' Voracy... Not a MMP Rapid or MHZ Racemaster (39'')
      • Crash
        • Oct 2015
        • 313
        #63
        no its not but, I do have a quote in my gmail for a phantom/Racemaster hull and hardware …………...lol
        have tentative plans of buying that hull and hardware and using my motor and esc
        just 600 short #gofundme
        Dear Dannie,
        enclosed please find photo`s of the ARTR hull. Included are:
        - Phantom hull C-AFK - 142,86€
        - Rudder (pop up function of rudder blade, incl. water intake - 91,60€
        - Strut for 3/16"
        - Brass / PTFE hose
        - flex shaft
        - Rudder steering left + right - 14,12€
        - water outlet - 2,94€
        - motor mount - 33,19€
        - ESC mount
        - rails
        - batterie mount
        - flex safety with bearing - 19,33€
        - support of brass / PTFE hose
        - outlet for strut - 6,72€
        - all assembled with polymer glue - 336,13€
        Total: 646,89€
        Further we could include coupling regarding to motor shaft size. Silicon hose + clips
        Best regards
        MHZ
        • Prodrvr
          • Jul 2015
          • 701
          #64
          I don't have a 36 Voracity...what am I missing?
          • Crash
            • Oct 2015
            • 313
            #65
            I emailed hiefie to get their opinion on my data log.
            • madmikepags
              • Aug 2012
              • 1371
              #66
              The over heating of esc's in boats at low throttle and on and off throttle is mostly because of parasitic drag, Airplane car and boat controllers are pretty much the same. How come I can run my Rc cars and planes on off on off all race and flight long. To accelerate a boat from off plane to on plane draws so much more amps than a car or plane. Remember your boat is in WATER, when you come off the throttle the boat wets down and then all you have is that little prop to get it back up to speed. For example I have a 1/5 scale 4wd on road car, it does about 60mph with a castle 2028 on 8S and I can get about 9 minutes of run time on 10,000mah going on and off the throttle the whole time. In comparison my sprintcat with the same motor on 10s and 12,000mah I get about 4-1/2 minutes running at 65mph. and thats mostly at full throttle for an offshore race. My huge 80 inch plane on 5000mah gets 7 plus minutes doing all out 3D maneuvers. The water is the limiting factor, when you go slow more of your boat is in the water and thus uses more amps to push it through the water.
              We call ourselves the "Q"
              • Crash
                • Oct 2015
                • 313
                #67
                "I’m Zoe from hifei technology, so glad to be at your service. Please don’t worry about it, our engineer told me that thers is no problem when you run the ESC at the partial throttle. Besides, you run your ESC at 80 to 90 % throttle threw will not cause damage to your ESC. If you have any questions, please feel free to contact me!"
                Thats straight from Sword Fish .
                Seems they are ok with partial throttle with the 300X
                • Crash
                  • Oct 2015
                  • 313
                  #68
                  I got 76 mph today at 82% throttle / 296 amps / 34,900 rpm / ESC 52 C. / 652 propeller
                  This boat is turning out to be just what I wanted, you can sport around in the 60 mph range and also lay down 90 mph pass if you have the nads to hold the throttle down....
                  • Prodrvr
                    • Jul 2015
                    • 701
                    #69
                    Nice!!
                    • Speed3
                      • Mar 2017
                      • 371
                      #70
                      Glad to hear things going well.
                      • Crash
                        • Oct 2015
                        • 313
                        #71
                        Its true what they , too much info is dangerous to the uninformed.....lol
                        I am reading my data log after runs and today I got ballsy and did a couple 100% pulls on the throttle to get some data.
                        The amp spike is expected but, the rpms seem to be way low threw out run at any throttle position.
                        Is it possible my motor cant turn this big prop as fast as its intended?
                        TP POwer 4060 3y / x652 prop
                        • Prodrvr
                          • Jul 2015
                          • 701
                          #72
                          Have the timing cranked up?
                          • Crash
                            • Oct 2015
                            • 313
                            #73
                            no , its set at 0
                            • Crash
                              • Oct 2015
                              • 313
                              #74
                              this is a 87% pull on throttle
                              • Prodrvr
                                • Jul 2015
                                • 701
                                #75
                                It's a Y wind motor. Set the timing to 10 and test. If all is well, keep bumping it up in increments to 15.
