I have added all of the OSE Feigao 380, 540 and 580 motors to the FeCalc equipment text file and attached it for download.
FeCalc - Feigao motors
ReddyWatts fleet photo
Mean Machine - Feigao 540 14XL, 8s, 100 amp HV esc, X537/3Tags: None
I might have removed the motor, controller or battery that you last ran in FeCalc and it is giving an error because it cannot find it.ReddyWatts fleet photo
Looks like some of the values were added with a double "tab" as they don't line up with similar motor values.
HTH
Ghost
Updated FeCalc file
I am using version 1.1.1 and it works fine. I have cleaned up the file, see if it works now.Attached FilesReddyWatts fleet photo
Thanks Reddy! Can you add a Lipo battery component where the user can enter the number of lipo cells, mah rating discharge rate (C), etc.? And, not for me but a lot others as well, can you add the new Etti 150 ESC? Steven from OSE is promoting them quite vigorously now...
FeCalc ETTI 150
I have added the ETTI 150 controller to the attached file.
Remember the Neu motors in the equipment file do not work well in FeCalc. I wish this program had a number of poles option. Seems to have been designed for two pole motors.
If you are running a Neu motor in a cat hull, you can cheat the program by entering "Hydro" in hull type and "Performance in hull attitude. This will get the amps fairly close, but throw out most of the other estimations.
.Attached FilesLast edited by ReddyWatts; 11-21-2008, 09:31 AM.ReddyWatts fleet photo
I wish it would let me edit that last statement. grrr......................
I think it would be best to not use FeCalc for Neu motor amp calculations. Use this chart instead for setups.
i cant thank you enough reddy
