blackjack questions
  • avengersteve
    • 395
    blackjack questions
    what is the shft size where the prop sits? i want to order a couple to play with (stock cable)
    going to leave it nitro till i get my transam rebuilt then doing a full blown conversion with stves OD idea.....
    restoring the collection
  • Steven Vaccaro
    Administrator
    • 8932
    The prop shaft size is real odd. about 2.75mm or so
    Steven Vaccaro
    • Piranha2
      • 320
      Isn't it the same as the Shockwave 26 EP RS? I use the Blackjack prop on mine.
        • 7512
        I spoke with Horizon Hobbies and they said its the same as used on the 1/12 Llumar , their Part # PRB2507, comes with the drive dog as well, I just received 2 yesterday.
        • avengersteve
          • 395
          ok, so pretty much if i want to play with diffrent props, ima have to change the shaft.... o well it will give me something to do later.
          • SJFE
            • 4867
            You have the new cable in the box i sent ya. It will be enough to do 2 cables. Order 2 prop shafts. A 3/16th for .150 cable and 3/16th turned down to 1/8th....then you can play with what ever props ya want.
