Water cooling system
  • lucky66
    • Jun 2018
    • 22
    Hello: my pro boat ,shockwave 26 is not putting out water on the side . Cleaned all the lines ,but stumped on the little box the inlet goes into .any tips would be welcome. Thanks
  • rol243
    • Apr 2017
    • 1038
    Take off the water cooling hose from the rudder and blow into it., you need to trace where its blocked.
    • lucky66
      • Jun 2018
      • 22
      Thanks : I had removed all hoses and did just that . still no water .hmmmmmm
      • rol243
        • Apr 2017
        • 1038
        check the rudder pick up.
        • 785boats
          Wet Track Racing
          • 3423
          Sometimes the nipples in the motor cooling jacket are clogged with the sealant that is used when they screw them in. The same thing happens on ESC's too.
          Use a drill of the appropriate size, that fits in the nipples, to ream them out, including the one on the rudder. Just do it by hand not in a drill.
