HELP with Hitex Aggressor Srx Tx
  • rcflyer55
    • 70
    I need help with my Hitex Aggressor Srx Tx. I put NiMH batts in it but I can not charge it with my charger. I think there must be a diod blocking it but I can't find it. Can someone post a pic of where it is and how to do it ?? PLEASE
  • Dr. Jet
    • 1759
    My Schulze chargers will not charge HiTec radios because of this diode. They like to talk to the batteries and this diode prevents two-way communication between the charger and the battery. I found a small circuit board in the battery compartment, but I simply opted to use a wall-wart or a cheaper charger to do my charging in-the-field.
    A nation of sheep breeds a government of wolves
    • rcflyer55
      • 70
      I like to cycle my batts during the winter and can't. I really don't want to remove them every month to do this. it's a PITA
      • rcflyer55
        • 70
        Can't believe no one has ever wanted to do this before. Any suggestions as to where else to find the info??
          I have the same problem with my Astro 110D. All I do is plug the charger into a "regular" NiMH pack for a few seconds until it recognizes the pack, the unplug the charger and re-plug it into the transmitter. This works great, but I don't know how well the charger will work to shut off the charge when the transmitter pack is full. Mine usually shuts off and I have never overheated the transmitter pack, but then I usually charge at pretty low rates.
          • rcflyer55
            • 70
            Thanks Fluid, Maybe I can try that with my 112D, I'm trying to use my Alpha 4 but it gives me "open" because it needs to read the voltage. I've jumped ever Tx I own but can't find this diod. Even did a search on Google.
