Playing with the big boys!
  • Peter A
    • 1622
    This is the result of racing with the big boys, gas boats 60" plus, they hate it when you beat them with a pursuit, but they just seem to completely fail to get off the gas and avoid smashing over other boats.
    My poor little pursuit, it will have to get a repaint later in the year now!
    Haha, love it. Hang in there Peter
    • Peter A
      • 1622
      Yeah I was leading into the last turn, stuffed in and came up under the 60+" MHZ boat that was chasing me. For not backing off or turning out he ended upside down. That's racing but it sucks to have to fix the boat again. The best part was suckering two boats into crossing the start early in both the last two heats, hard going in the tsunami size wakes those boats make, couldn't even get to full throttle!
        Yup that wake is killer from the gassers. They are setup to be ‘stuck’ to the water.
        I was running with a few at the now defunct pond with my DF 35 and I was good if in front but if there was a rogue wake I was over.
        I applaud your running Peter. Try and get some vid please.
        Shawn
        • properchopper
          rcgoatbuild@snotmail.com
          • 7708
          Ah, memories (Tyler driving my DF33 in an "open class" sprint race)
          • properchopper
            • 7708
            Gassers use welded metal starting tables at the water's edge. They've been known to jump out in front of you..................
            • rayzerdesigns
              • Dec 2013
              • 1228
              I race against gas guys all the time.. can’t put the blame on them.. sometimes it just happens
              • Doug Smock
                • 5359
                I'm a gas guy too and am offended by this post...
                MODEL BOAT RACER
                IMPBA President
                IMPBA 19887L CD
                NAMBA 1169
                • properchopper
                  • 7708
                  Here ya go
                  Truthfully, the D19 gassers are responsible for the rebirth of FE racing in SoCal. Great guys all
                  (they do however churn up the h20 some )
                    [ATTACH=CONFIG]160153[/ATTACH]
                    Hi Tony,
                    How are you?!
                    That is pretty impressive damage, but your repair was even more impressive and spectacular.
                    Happy 4th of July.
                    Cheers,
                    Tim
                    • properchopper
                      • 7708
                      Hi Tony,
                      How are you?!
                      Happy 4th of July.
                      Cheers,
                      Tim
                      Thanks Tim
                      • Peter A
                        • 1622
                        You haven't seen our guys run! They are real good at not letting go the throttle and smashing another boat. Race haze of some sort, a need to have to try and win at all costs, get inside of the other boat and beat them to the corner or at the corner regardless of whether there is room or not. Happens too often.
                        Yep sometimes things just happen, but often it can be avoided, especially if you would rather finish with an undamaged boat rather than just win a club day race.
                        • properchopper
                          • 7708
                          In NAMBA D19 events (IC or FE) the first and second place finishers of a heat must act as corner judges for the next heat. Infraction lap penalties and DQ's are dished out as needed.
                          • Peter A
                            • 1622
                            We can struggle for numbers on club days, sometimes only having one person to help launch and another to lap count. The launcher usually goes and helps the lap counter call dead boats etc. Sometimes "spare' people are just busy sorting their boats between heats etc etc. All the usual stuff. Working on it....
                            1st and 2nd as corner judges, not a bad idea that, I will keep that in mind for the future.
                            • properchopper
                              • 7708
                              In order to eliminate crooked judging/favoritism we sometimes have found the need to resort to unquestionably trustworthy judges
