Advice needed 54" seamaid electric drive scale performance
  • Givit
    • May 2018
    • 4
    Hi
    I am scratch building a 54" seamaid century and need advice on power train.
    I will need to push along appox 8-9kg of 1400mm of boat
    question what will spin 60mm prop at scale speeds ,,30-50kph. (60mm prop is only scale size i could use smaller)
    I would prefur to run around 3-4s 14v batteries or SLA 12v
    even a brushed motor but dont think theres any to suit.. maybe small (JOHNSON RS-775 )?
    I have a castle 800kv motor and esc but thinking this is mass overkill unless geared down.
    What is the normal electric size replacement for a 260pum gas drive line and prop size? as i think this would be good suit but i want electric.
    Thanks any advice maybe looking for power calculator?
  • Givit
    • May 2018
    • 4
    So in the past i had the local print shop scale up these plans 200% and built for my kids.
    Now will build as the 1/4 scale plan. I really need suggestions for a starting point for power drive train. motor,shaft,prop?.
    approx 18lb 55"long 13"wide, submerged prop . I can build motor mounts, plates for gears all that. I estimate around 800watts will be needed open to suggestion
    I have experince in the rc hobby all will be tested using Watts meter, and am willing to listen and take on board any help in this project.
    • Peter A
      • 1624
      That castle is a replacement for a gas motor. On 4s with a 60mm prop you would be somewhere around 35kph. You will need plenty of mah though for decent run time.
      • dasboata
        • Dec 2010
        • 3972
        If it's for the kids look for a jet drive or even making one a lot safer
        • Givit
          • May 2018
          • 4
          Funny you mention i do have a Swashdrive unit.
          no the rc 1/4 scale is for me.
          I thought the 2028 would be overkill, well thats good i have existing 4s 6000 graphines for losi 5ive runs 2028.
          any ball park amp draw thoughts, as i will need purchase WC ESC 150 maybe?
          • larryrose11
            • Jun 2010
            • 768
            The jet drie would be much more safe with kiddos.
            A used golf cart setup may be the easiest to get going. They are usually 48V, and have a built in charger. They usually have a lead acid batteries, (trojan T05, 100 Ah, 6v) which may be fine for this application.
            if you want to buy new equipment, this may be a good resource:
            • larryrose11
              • Jun 2010
              • 768
              A jet drive for a WaveRunner can be purchased from eBay
              https://www.ebay.com/itm/95-96-97-98...torefresh=true
              • Givit
                • May 2018
                • 4
                https://www.electricmotorsport.com/marine
                That was my prefured drive line for finnished kids boat,but at close to 10k and having 6yr olds doing 30+knts, no.. $200 for trolling motor.
                So far with this project for 55" 1/4 scale, from suggestions i will run
                4s batts, to ESC???, to castle 2028, to 5mm ss prop shaft, to 50-60mm prop but at what pitch 2 0r 3 blade? to remain around 100amps region
                I dont need chine walking speeds just on plane
                Thanks
