Warning: Trying to access array offset on null in phar://.../vb/vb.phar/bbcode/url.php on line 2 Blackjack 29 v3. 6s 55mph comfortably. - RcBoaters Forum
  • jake414
    • Mar 2018
    • 64
    I recently posted about batteries.. I ended up getting 2 3s 5000mah 60c...
    First run I shot the flex shaft out of the back along with the prop. I have all stock flex shaft etc.
    I am wanting to build this boat to run a comfortable 55mph since I already have to buy a new prop.
    I was told to get the following :
    https://www.offshoreelectrics.com/pr...od=ose-1390-v3
    https://www.offshoreelectrics.com/pr...ct-ocfhe5mm15S
    https://www.offshoreelectrics.com/pr...-bj29-v3-cable
    and a flex cable saver.
    I have read ALOT on how the 2000kv motor is too much and to switch to a 1500kv motor. But some people I see are running leopard 1900kv, along with the seaking 180a esc. For NOW id like to leave the esc stock, if I can get a comfortably running 55mph on a new motor and stock esc.
    So I am thinking, New Leopard 4 pole 3674 1650KV motor and a x440 prop.. Or what motor that's 1500kv is everyone referring too?
    please shoot holes through my plans. Tell me what wont work and what will.
  • rol243
    • Apr 2017
    • 1038
    Forget using a 2000 kv motor on 6s unless your only going to do saw speed runs. really the max kv motor for 6s is 1600 kv,s but the 1500 kv would be a safer option. the 3835- 1500 Dynamite motor is good for your boat to run well on 6s.
