39'' catamaran twin setup RPM ?
  • Alfa Spirit
    • 2131
    What is the normal RPM for a 39'' catamaran, 30.000 or 40.000 ?
    Thank you
    • 7990
    What is the planned use? What are the desired speeds? Desired run time? Narrow hull?
    • Alfa Spirit
      • 2131
      I don' t want a speed saw monster, I want a fast cat to have fun with friends. I saw videos on Youtube like this one , 2 x 2150 kV on 6S so near 47.000 RPM.
      Is this a "standard" or a saw setup ?
      • hughb
        • 152
        47000 RPM-I would say that’s a definite saw setup. Prop selection would have to be spot on, too big or too great a pitch will draw so many amps you’ll burn out your equipment. Maybe aim for around 30-35000 RPM for a boat that will have some longevity.
        • boredom.is.me
          • Jun 2009
          • 595
          Higher power requirements also means less run time. I'd rather have a slower boat and play longer if I'm with friends.
            • 5660
            https://www.youtube.com/watch?v=X4X7y6biCwA&t=100s
            jUST RUN 4S and you can have a lot of fun. Why bother to use 6s if you don't need the speed. 5s will give you a big smile, I won't go for 6s....
            • Alfa Spirit
              • 2131
              Thank you guys,
              I have a set of 1512 1900kV motors, they should be fine with 5S 5000mAh batteries.
