who's running a 2028 Castle
  • dasboata
    • Dec 2010
    • 3972
    I guess they need a 1/4 shaft ,, I figured turning a 457/3 I would be good,, but I guess the 11 HP destroyed the 3/16 shaft is 50 ft live and learn what about the long motor shaft does that need to be cut so the collect is a little closer to the motor I'm thinking it should ,,
  • RaceMechaniX
    • 3024
    I run 1/4” with mine.
    Tyler Garrard
    NAMBA 639/IMPBA 20525
    T-Hydro @ 142.94mph former WR
    • rol243
      • Apr 2017
      • 1038
      I guess the 11 h.p. electric would be simular to a 90 size glow engine , 1/4 inch shaft for sure.
      • dasboata
        • Dec 2010
        • 3972
        Thanks guys Tyler what about the Long motor shafts I have at least 5/8 of exposed shaft behind the collet thanks chris
        • rol243
          • Apr 2017
          • 1038
          Chris, if the shaft was a 5mm diameter size i would cut it down shorter but being an 8mm it should be fine at that spacing.
          • dasboata
            • Dec 2010
            • 3972
            Yes it 8 mm thanks man
            • RaceMechaniX
              • 3024
              Chris,
              I don't like extra shaft off the end of the motor if I can avoid it. I did cut the stock 2028 shaft down so I only have room for a thrust washer if needed and the collet.
              If cutting the motor shaft means you need to replace the flex shaft too, then it can probably wait.
              -Tyler
              Tyler Garrard
              • Moonie
                • Jan 2014
                • 343
                Chris,
                -Tyler
                Me to.
                Gold Spilo
                • dasboata
                  • Dec 2010
                  • 3972
                  Chris,
                  -Tyler
                  You know I knew that,, I just needed a little push LOL , reciprocating mass like that hanging off the end of the shaft could do some damage if suddenly goes out of balance , where if it was cut shorter and closer to the case it would be much safer and less vibration thanks Tyler
                  Originally posted by Moonie View Post
                  Me to.
                  Yea and me too lol need that push ,,,I have to re do the drive line anyway to 1/4". I'll just take the cut off wheel to it thanks Chris
                  • rol243
                    • Apr 2017
                    • 1038
                    pretty hard to bend 8mm hardened steel thats only about 1 inch long.
                    • RaceMechaniX
                      • 3024
                      The biggest reason is to reduce the radial forces on the bearings from any imbalance in the coupler and/or shaft.
                      Shorter shaft and a snug fitting coupler are key.
                      Tyler Garrard
                      • dasboata
                        • Dec 2010
                        • 3972
                        not at 30,000 rpm better safe then sorry thanks guys !!!!
