Mystic ARTR 1140mm 44" from Germany, how good is it.
  • Tbauer
    • Aug 2012
    • 261
    You doing the build? Or gonna have the builder post updates?
    • Speedfreek
      • Apr 2018
      • 276
      Its a ARTR then i am putting extra cfk where the deck joins to the hull, esc motors rx hatch seal srews so on so on.
      MYSTIC 138 119 MPH so far
      • Tbauer
        • Aug 2012
        • 261
        Oh that's awesome, I wonder when they started doing that....... What is the build time?
        • Speedfreek
          • Apr 2018
          • 276
          I was originally going to get a white one and paint it and the guy there said there is a air brushed one here ready to go for a little extra, so being that it's a limited amount getting done like this, i said why not.
          Shipped out the next day
          • Speedfreek
            • Apr 2018
            • 276
            Has anyone used a MPS switch to disable there rx ?
            I just don't understand it's use realy
            • Tbauer
              • Aug 2012
              • 261
              Hell ya!
              • Speedfreek
                • Apr 2018
                • 276
                • rol243
                  • Apr 2017
                  • 1038
                  may i ask whats the extra electronics for ? extra reliability or extra troubles ??
                  • Speedfreek
                    • Apr 2018
                    • 276
                    Not quite sure what it is for, just asking if anyone uses it ?
                    • rol243
                      • Apr 2017
                      • 1038
                      yes thats new to me aswell, wonder why you would want to disable the receiver with another electronic unit when you can just unplug the power via the normal lipo plug . better to keep things simple for less worry of failures.
                      • Speedfreek
                        • Apr 2018
                        • 276
                        Exactly, it's a magnet which cuts the circuit very basic but i don't understand why you would use it.
                        • rol243
                          • Apr 2017
                          • 1038
                          The only time you would use a receiver on/off switch would be when you have set up a separate battery pack to power the receiver and servos. to do this you must unplug the Red wire from esc to rx then plug in your rx switch harness to the receiver and battery pack. this set up can be a safer way to make sure you always have power to your onboard radio if something goes bad in the esc / bec. LiFe 6.6 volt packs are great for this set up, also a J.R. gold plated teminal rx switch are very reliable.
                          • Speedfreek
                            • Apr 2018
                            • 276
                            The next question is what prop to use on a 44in Mystic 2x TP power 4070 1750kv 2x XLX's for (maximum) speed ?
                            2 blade or 3 blade pro's and con's.
                            Prop guys please chime in .
                            • rol243
                              • Apr 2017
                              • 1038
                              Might need to know SAW or Oval for prop selection.
                              • Speedfreek
                                • Apr 2018
                                • 276
                                These props will be for Saw, max speed only
                                23kg Might be overkill but had it laying around.
