Aveox and Hackar motors
  • old guy
    • 710
    I just found these in a box of my RC stuff I got them in a trade awhile back
    1st is a Aveox 36/30/1.5 1980 Rpm/v Io 3.9, 60/100/40A Bla bla bla bla
    2nd is a Hackar HBR B50 8L 3019 u/v not so many bla bla on this one
    3rd is a Hackar B-50-8s 4613 RPM/V
    so becouse I know nothing about FL what do I have and what can I put them in and how many cells will they take? is one of these any good for a rigger and if so how many cells?
    36/30/1.5 what does that meanand what about the 60/100/40A on the same motor
    Thanks for the Help
    Old Guy in the woods
  • Darin Jordan
    • 9446
    Not sure about this one... Sounds like a smallish motor that might run well on 3S to 4S Lipos??
    That is an excellent 8-cell motor that used to win a lot of O-Sport and O-Mono races... Would be a good Mono motor on 2S Lipos for offshore or sport running... about 25,000 RPM or so... Or a screamer on 3S Lipos at around 36,000 RPM...
    That's a hot motor on 2S... and a little smallish... Maybe a smaller 2S Rigger or light sport Hydro?? You are looking at around 36,000 again, only on 2S this time, so more amps...
    Would be a good 6 or 7-cell small sport hydro motor as well... if it's light and aired out...
    Darin E. Jordan - Renton, WA
    • old guy
      • 710
      Thanks the Aveox is about 3/32" wider than the B50 8L and about 3/16" longer
      If this helps any one
      would this be a good cheep ESC for the motors I would like to go cheep untill I know more It's not so bad when you smoke a cheep one?
      HiModel GX Seires 200A 3-7S Brushless Electric Speed Controller Type GX-200A-OPTO from manufacturer HiModel, in category Brushless Speed Control (BL ESC) - Air/ Helis, Electric Speed Control (ESC).
      does Feigao or any one make a cheep motor the size of a Neu 1515/1Y/S
      old Guy
      • Dr. Jet
        • 1759
        That Aveox motor is the forerunner of the Neu 1512 motors. The 4-pole rotors are interchangeable. That is a great motor for 4S applications. It has a ton of torque and it is nearly (but not completely) as efficient as the Neu. Any cheap Chinese ESC capable of 80~120 amps would be fine for that motor in a “sport” setup. It is better (in my opinion) than most 2-pole motors currently available.
        A nation of sheep breeds a government of wolves
        • old guy
          • 710
          Made a mistake I should have said does Feigao or any one make a cheep motor the size of a Neu 1521 1D
          Old Guy
