Twin XLX Zonda what TP Motor and props ????
  • Speedfreek
    • Apr 2018
    • 276
    As the title states, modifying two XLX's waterproofing, cooling mods from ideas on this site thanks guys .
    I have been running the XLX in my rc car and know all the ins and outs of the software and i love it.
    So the big question is what size TP Can 40?? should i get and what kV ?
    Going to be 6S per ESC .
    Looking for best of both worlds run time and speed 80mph
    Turnigy Graphene batteries Specs:
    Capacity:*!**5000mAh
    Voltage:*!**6S1P / 6 Cell / 22.2V
    Discharge:*!**65C Constant / 130C Burst
    And what prop to use with it ?
    Rx and servo will be powered by a 6.6V life battery even tho two XLX's have 20A bec each
    And it's in a Zonda.
    I have to stop looking at this forum, you guys keep giving me idea's and i keep spending more money
    MYSTIC 138 119 MPH so far
    • 4340
    TP4050 1460kV, 1570kV, 1700kV variants on 6S will put you right around the 30K RPM range and is a good size motor for that hull.
    • Speedfreek
      • Apr 2018
      • 276
      Nice nice what do you think of 4060 1700kv ?
      Isn't the magic number these days 40k rpm range so i have been told or is the Zonda not capable of doing this?
        • 4340
        Your RPM depends on what you want out of the boat. I'm using 4060 2450kV motors on 5s in my 45" cat for SAW runs. I'm also going to run a 4060 1750kV on 6s in my 37" Genesis, again for SAW runs only. Both of those setups will be around 45K RPM, unloaded, and will have only enough battery for a handful of passes. Search for existing builds on that hull and research what people are running setup wise and what the resulting speeds and run times work out to be.
        • Speedfreek
          • Apr 2018
          • 276
          Thanks for the reply, i have searched until my head lots and lots of info
          Just want to lock it in now .
          Ok 4060 locked in, now for kV 1750 or 1950 , my head hurts
          • Speedfreek
            • Apr 2018
            • 276
            Can i get some help
            This is what i do know, the 1750kv is a 3Y 213A 29v
            And the 1950kv is a 5D 248A 25.6V, which is where about a 6S Lipo is fully charged
            What does that 5D, 3Y mean ?
            What is better ?
              Your RPM depends on what you want out of the boat. Search for existing builds on that hull and research what people are running setup wise and what the resulting speeds and run times work out to be.
              Careful where you send him Ryan, lol.
                Can i get some help
                What is better ?
                Ok, a 6s lipo under load will likely pull down to 23-24 volts so you can get the readings from that more realistically.
                If you are not experienced yet too much go with the 1750 3y.
                Y & D are in relation to how the winding in the motor are done. The numbers are how many winds of wire are in the motor.
                • dmitry100
                  • Mar 2015
                  • 1264
                  I have a TP 4050 2050kv motor in great condition available in the for sale section, in case you are interested.
                  It would run good on 5s or 6s. I ran it on 6s and clocked 107mph with it
                  If you are looking to run it as a twin, I have a second motor that is exactly the same which I can also sell.
                  • Speedfreek
                    • Apr 2018
                    • 276
                    Thanks i might go for the D wind, even tho i am not that experienced, i don't want to be purchasing lots of motors to get to 80 ish mph.
                    So 1950 kv seems like the one to get no !
                    • Speedfreek
                      • Apr 2018
                      • 276
                      Wow how good is that, yes it is a twin and from what i read on the forum here the 4060 is good at holding rpm (torque) but thanks for the offer
                      • Old School
                        • Aug 2017
                        • 686
                        From what I have read a D wind will run cooler with more torque and a Y wind will spin faster with more heat. A "D" wind should be "timed" between 0 - 3.5 and a "Y" wind timing is usually factory set on the ESC at 15, but I prefer 11.25.
                        • Speedfreek
                          • Apr 2018
                          • 276
                          Thanks for the extra brake down i appreciate it
                          What part of Australia are you ?
                          • Old School
                            • Aug 2017
                            • 686
                            I am in Sydney.
                            • Speedfreek
                              • Apr 2018
                              • 276
