Guys, setting up a new ml boatworks 335 sport hydro and i have 2 x motors that i was thinking on using but maybe they could be abit too small. one is a t.p. 3650-2350 kv and the other is a castle neu 1415 - 2400 kv motor. wanting to run on 4s1p . do you think i do need to go up to a 40mm motor and lower kv,s ?
33 inch sport hydro motor size ?
Exactly what hydro are you talking about? Some are easier to push than others. How do you expect to run the boat - oval racing, sport running, or zipzip running? What packs - capacity, C-rating?
Not knowing the above, I’d suggest a 40x82 size motor with a Kv between 1850-2200.
I think the motors in your first post are too small. The 4050 will probably work well.
I used to run a TP Power 4060 5D in my 33" Whiplash, and it was as quick as anything else (it was 2040kV back then - TP alter kV from time to time). No problems using 5800 1P packs with it. I used a de-tongued 447/3 prop.
Are you running at the Pine Rivers club? That's where I raced.
