Whats a very reliable ESC
  • Speedfreek
    • Apr 2018
    • 276
    Looking at 2x ESC's whats a reliable 8S 200A plus system with or without internal bec water proof would be good too ?
    Looking to do high speed runs around 80 90 mph.
    I am sure i have left something out boat is a Zonda
    MYSTIC 138 119 MPH so far
  • R2315
    • Aug 2016
    • 199
    MGM https://www.mgm-controllers.com/race...x2-series.html
    Swordfish https://www.offshoreelectrics.com/pr...d=hef-HBX1300L
    https://www.offshoreelectrics.com/pr...ef-HBC1240L-CW
    Might have more options if you dident need 8s but it's a start.
    • R2315
      • Aug 2016
      • 199
      By the way, those swordfish esc's are fairly large the new 220 is smaller https://www.offshoreelectrics.com/pr...d=hef-HBX1220L but up to 6s
      • Speedfreek
        • Apr 2018
        • 276
        This one looks good.
        • Speedfreek
          • Apr 2018
          • 276
          Toying with the idea of converting and waterproofing a XLX i love em, and can handle up to 400A with data login and the right price too, has any one successfully dun this mod.?
          • eric113
            • Sep 2011
            • 327
            The esc only goes up to 6s. OP was asking about 8s.
            • StevenBryant
              • Nov 2012
              • 359
              Yes I’ve done several XL2 and XLX, make sure you replace the caps on the board with Rubycon ZL 50v 680uf. I put 4 caps on the power side of the esc.
              • R2315
                • Aug 2016
                • 199
                I know, Just a suggestion in case he changed his mind and went 6s, could save a bit of money and space going 6s.... just putting it out there. What motors are you running?
                • Speedfreek
                  • Apr 2018
                  • 276
                  Have you got any picks or link of how you did the water cooling on it ?
                  I even add extra 5 caps 50v 2200 uf to it and data log says 1.6 ripple with 6S
                  How are thay holding up in the boat ?
                  • R2315
                    • Aug 2016
                    • 199
                    Here is a link to a aircraft controller Fluid did, not sure if you could use a similar method. https://forums.offshoreelectrics.com...ght=castle+esc
                    • Speedfreek
                      • Apr 2018
                      • 276
                      Cool thanks all ideas are good thanks for this one
                      • R2315
                        • Aug 2016
                        • 199
                        Maybe this too! https://forums.offshoreelectrics.com...r+cooled+mamba
                        Man, he does some nice work!
                        • Speedfreek
                          • Apr 2018
                          • 276
                          That's exactly whats bouncing around in my head
                          Do you now if it is still going , worked ?
                          • R2315
                            • Aug 2016
                            • 199
                            Sounds like it worked you could always msg kfxguy if he doesn't see this
                            • Speedfreek
                              • Apr 2018
                              • 276
                              Not sure how to yet, will give it a try
