Originally posted by danzuby
View Post
TP 4050 1950kv on 6s
Sounds good and makes perfect sense thanks for your time.Originally posted by Speed3 View PostI suggested the lower kV 1650 4060 because I have learned lower kV is much easier on the electronics.
The 1650kv combine with a m545, m645 should pull amps in the same area as the 1800kv x642 setup.
But the m545 is a faster prop than the 642 and the tp 4060 will hold the rpm better underload. So I feel by reason of prop efficiency and motor efficiency. You should see better speeds than what you did before.
