The hull is SUPER light. I don't have a scale that can weigh this light, but my Renegade rigger with motor and CC Phoenix 25 ESC, & RX weighs roughly the same as this hull & HW.
Graupner SX4000 - finally here!
The XL will not fit because of the angle of the motor mount, but an S will, maybe an L, but I don't have one to test fit.
The hull will not flex anywhere near as much as the blizzard, renegade, and Graupner silver bullet. I may want to pad the nose a bit, just because I may hit something with her."A quick temper will make a fool of you soon enough."
I have both dial and digital calipers ... you can borrow the digital or the dial type (as this is is better - Brown & Sharpe) top of the line for calipers! Or if you want I also have Starrett mics to get a more precise measurement.Originally posted by Diegoboy View PostThe tub is roughly 2-1/2" wide.
I just installed 2 of my Poly RC 4S 3000mAh lipos inside the tub, no sweat!
Sorry for the dark pic!
The coupler set screws are mm. the wire? I don't know the size, but I'll find out tomorrow when I get my caliper.IMPBA 20481S D-12
The wire is a .56Originally posted by Ub Hauled View Postyup, you are good for N2
how wide is the inside of the tub? will it fit most lipos?
How about the coupler and the screws, are they mm or imperial?
Is the shaft a .68 or one of the german sizes?
the boat hull w/ HW weighs in at a whopping 18.2oz"A quick temper will make a fool of you soon enough."
Danny, what are you power schemes...ESC..LI-PO etc. Any of the XL motors are a bad choice for that hull size The S and L are better dependant on prop and your final power scheme. Neat looking rigger
Douggie
Thanks,
I plan on a lehner 1930/4 5225kv on 2s2P
Maybe a Neu 1506/1Y?"A quick temper will make a fool of you soon enough."
I don't have an ESC planned yet, but I plan on the V937/3 prop"A quick temper will make a fool of you soon enough."
Gunnar had the record (93+mph) now Brian has it with a 1512Originally posted by Diegoboy View PostThanks,
w/ the 1920/4 or 5.
just an FYI
J.M. I think he was planning in using the packs in parallel...:::::::::::::::. It's NEVER fast enough! .:::::::::::::::
