Recovery boat.. What does everyone use
  • Nick1979
    • Sep 2020
    • 118
    #76
    Thanks for that information. In my experience in a recovery boat reverse is a must. I have ended up on the shore and wasn't able to back up die to no reverse... Also, of the disabled boat is far away, where it's hard to see, scooping the disabled boat becomes a challenge. Having reverse helps. All of the above made me build an air boat, which has reverse.
    • Panther6834
      • Apr 2020
      • 708
      #77
      Originally posted by Nick1979 View Post
      Also, if the disabled boat is far away, where it's hard to see, scooping the disabled boat becomes a challenge. Having reverse helps.
      I'm definitely in agreement on a rescue boat needing reverse if it's using a review platform. Regarding rescuing a boat Russia "a distance", that's why I installed an FPV camera onto the canopy of my primary rescue boat, as well as a display monitor onto that boat's Tx.
      • UpliFT-RC
        UpliFT-RC
        • Jun 2019
        • 126
        #78
        Originally posted by jake414 View Post
        Getting my revolt 30 here soon hopefully..
        For the time being I'm going to use a fishing pole with a tennis ball, but eventually want a CHEAP recovery boat.
        So this has brought me to the used cheap boat market and ebay.
        this boat will ONLY be used as a recovery boat, doesn't have to be fast or anything. Looking for 2.4ghz (obviously) and atleast 5 minutes of run time.
        this def isn't hobby grade : https://www.ebay.com/itm/PX-16-1-16-...0AAOSwGHJaZ~aY
        BUT it has a lipo battery and seems to be maybe a deans plug. and its fairly big?
        https://www.ebay.com/itm/Genuine-Fei...gAAOSwWxNYq7ng
        this also has a lipo.
        My thinking is, these small lipos can be had very cheap so it would be easy to get more run time..
        Thoughts?
        I just got the new ProBoat BlackJack 42 and I was looking for a nice recovery boat.. After doing around a month or so of research, I decided to go with the -
        Feilun FT011 65CM 2.4G Brushless RC Boat that is a water cooling system. Plus it has a pretty cool nose guard where I can hook on my recovery system that I have in mind...
        Feilun FT011 Review
        https://[url]https://www.youtube.com...[/url]
        BJ42'' / Miss Geico 36'' / TFL Hydro 35'' / Retrieval boat 30'' Tug
        Make sure you check out my Youtube channel -----> shorturl.at/ntFQ7
        • boatsrnew2me
          • Oct 2016
          • 474
          #79
          keep in mind that during a rescue you will be moving pretty slow most the time ......lining up the boat......pushing back to shore........the motor will not get much water cooling effect at those speeds .
          thats one the reasons i went with a brushed motor boat . motors are bigger and can dissipate their own heat better and some have heatsinks .
          most tugs are brushed motor or twin brushed motors for the same reason . just something to think about . you could add a water pump to pump cooling water thru the system at low speed .
          • zooma
            Local club FE racer
            • May 2014
            • 653
            #80
            Using an outrunner airplane motor and SeaKing ESC without water cooling. Current is too low to matter.
            Ron - The Villages, FL
            • Panther6834
              • Apr 2020
              • 708
              #81
              I'm about to take my ProBoat Shockwave "rescue" boat in a new direction, and looking for some thoughts on what I'm proposing. The 'plan' is to take it from "one of my 3 part time rescue boats" (the other two are a TFL Jet Boat, and a Tenshock Mini Eco), and torn it into "my only full time rescue boat" (this making the other two 100% "pleasure use").
              Right now, I've got a dual-rudder, with the water line from one rudder cooling the motor, and the water line from the other rudder cooling the ESC. The ESC (which will remain) is a SeaKing 120A, the motor is a Leopard 3650 1350kv, and the prop is the stock 42mm plastic prop. The 'problem' has been keeping the motor & ESC cool, as the slower speed prevents the water pickups from pushing (pulling?) enough water through them lines. Remember that the stock motor is 2000kv.
              So...here's what I'm looking to do. First up is to replace the 1350kv with a 1050kv motor. Next to install two 370-based water pumps, to keep water flowing through the system no matter the boat's speed (even when the boat is motionless). Third is too replace the stock plastic 42mm 1.4 pitch (or, if it 1.6?) prop with a larger diameter (and possibly lower pitch) prop. To start in I'll be testing the plastic Octura 1245, 1250, & 1450 2-blade 'chopper' props. I would have preferred to include some 3-blade props, but I couldn't find any plastic 'chopper' style props in the 42-46mm range. While I'll (probably) eventually go with a metal prop, I prefer testing using the plastic props, as they're a LOT lower on price.
              For those who know boats better than I do, what are your thoughts...on the motor choice and/or my planned use of water pumps and/or my current prop choices? Obviously, the purpose isn't 'speed'...it's "go slow, but with a lot of torque". The dual-rudder setup allows turning equally well in both directions, even when pushing the rescue platform w/ rescued boat.
              • UpliFT-RC
                UpliFT-RC
                • Jun 2019
                • 126
                #82
                Here is how I will be building my recovery boat system...
                Here is an example of the recovery system that I will be creating for my
                Feilun FT011 boat
                • Panther6834
                  • Apr 2020
                  • 708
                  #83
                  The latest "downgrades" to my Shockwave 'rescue boat' are complete. Installing the Leopard 4074 1050kv it Shockwave proved a little more difficult that expected. I had to take the trusty Dremel to the black (shiny) plastic piece that the mounting tray is attached to, sure to the larger motor diameter. Once that was complete, I moved into swapping the stock strut & flex cable with the OSE Cable System w/ 3/16" strut. After that, I installed the two 370-based water pumps (just in front of the transom). 'Home testing' was completed in my usual "testing facility", aka the bathtub.
                  As the 1040kv motor is, obviously, slower than the 1350kv motor I had tried using, and a LOT slower than the Shockwave's stock 2000kv motor, I knew I needed to go with a larger prop (stock, if I remember correctly, is either 39mm, or 41mm...honestly, I didn't measure it). I selected the OSE 3-blade 47mm...which, as some of you probably know, is a 'cleaver' style prop, and not really appropriate for what is now essentially a (fast looking) "tug". On top of that, with the dual-rudder, to 47mm turned out to be sightly larger than would fit (when the rudders are full-left, or full-right). So, out came my trusty Dremel (again). Not only did I make the prop smaller in diameter (44mm, having removed 1.5mm from each blade), but I also changed it from a 'cleaver' prop, to a 'chopper' prop.
                  If all goes as I'm hoping it will, I will be doing a full-on "working" test tomorrow. Just hope I don't forget the temp gun (which I have forgotten in the past). If all goes well, I will consider my Shockwave as my permanent 'full-time' rescue boat. That's what I am...or, will be...using as my rescue boat from now on.
                  • UpliFT-RC
                    UpliFT-RC
                    • Jun 2019
                    • 126
                    #84
                    Zipkit Tug Recovery boat for the Black Jack 42..
                    ProBoat BlackJack 42 Ripping Laps on 8s on a new #Dasboata Prop incl. Recovery Zipkit TugBoat for the rescue...
                      Originally posted by HammertimeAZ
                      I dont take my boats to the biggest lakes in town but I always carry a light weight spinning fishing rod with a weighted Styrofoam bobber. Fingers crossed, Ive been able to get myself out of most pickles. I know its not a boat but it is one hell-of-a retriever!
                      What line weight do you use? Fishing rod is always a great go to if it's not too far out.
                        [ATTACH=CONFIG]173045[/ATTACH][ATTACH=CONFIG]173046[/ATTACH]
                        What timing would you recommend for a recovery boat like yours? I have a 600KV 5055 outrunner on 4S.
                        I just bought all the tubing yesterday and I have everything but pool foamies and a prop so far.
                        I'm looking forward to getting out and testing with less worry of boat loss.
